nicenoise
| Output current limitation ? |
Posted: Fri Dec 14, 2007 8:22 am |
hello,
i have a problem using the RA5 pin of a PIC16f688.
I use this pin to supply 2 analog sensors with 3.3V.
This need 7mA only to work!!!
i´m using a lithium batery regulated to 3.3V and when i put the line HIGH the out is only about 2.5V, not 3.3V . This is very strange, its look like the PIN RA5 that cant give the current necesary and down the voltage. The specifications say 25mA maximum current every PIN.
I think the hardware is ok, is this a software limitation???
any ideas????
thanks a lot!!!!!
alex
This is the code,
#include <16F688>
#device ADC=8
#fuses INTRC_IO,PUT,NOMCLR, NOWDT,NOPROTECT,BROWNOUT
#use delay(clock = 8000000)
#use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5, parity=N, bits=8)
//#use STANDARD_IO(A)
//#use STANDARD_IO(C)
#define x18 PIN_A0
#define y18 PIN_A1
#define xrate PIN_A4
#define yrate PIN_C0
#define x3 PIN_C1
#define y3 PIN_C2
#define z3 PIN_C3
#define pulsador PIN_A2
#define bateria PIN_A3
main()
int i = 0;
long val = 0;
int flag1 = 0;
int flag2 = 0;
int sensor[7] = {0,0,0,0,0,0,0};
//set_tris_A(0x00);
//set_tris_C(0x00);
setup_adc( ADC_CLOCK_INTERNAL );
setup_adc_ports( sAN0|sAN1|sAN3|sAN4|sAN5|sAN6|sAN7 );
set_adc_channel( 0 );
output_high(PIN_A5);
if( (!input(pulsador)) && !flag1 ) // pulsador
flag1 = 1;
putc(209);
putc(255);
delay_ms(10);
putc(209);
putc(255);
else if ( (input(pulsador)) && flag1 )
flag1 = 0;
putc(209);
putc(0);
delay_ms(10);
putc(209);
putc(0);
if( (!input(bateria)) && !flag2 )
flag2 = 1;
putc(210);
putc(255);
delay_ms(10);
putc(210);
putc(255);
else if ( (input(bateria)) && flag2 )
flag2 = 0;
putc(210);
putc(0);
delay_ms(10);
putc(210);
putc(0);
for(i=0;i<8;i++)
if(i!=2)
set_adc_channel( i );
delay_ms(1);
val = read_adc();
val = (val*200)/255;
if(val != sensor[i]){
sensor[i] = val;
putc(201+i);
putc(val);
Posted: Fri Dec 14, 2007 8:38 am |
Logic lines, will never go 'to' the supply line, when under load. The 'output high' specification for your chip, is Vdd-0.7v at 3mA, using a 4.5v supply, on the industrial version chip. The normal versions have the same droop, at a lower current of just 1.3mA. On a lower supply, expect this to be slightly worse (the internal gates don't get turned on as hard), and with your higher current. What you are seeing, is totally normal for the outputs.
nicenoise
Posted: Fri Dec 14, 2007 9:54 am |
thanks,
but if i put a pull up resistor (1k or minus), its possible that this voltage go to 3.3V????
any diferents option??? |
amcfall
Posted: Fri Dec 14, 2007 10:08 am |
| nicenoise wrote: | thanks,
Use a transistor to switch the voltage.
Avery |
nicenoise
Posted: Fri Dec 14, 2007 11:06 am |
yeah,
i had had a smd mosfet, the bs170, but it was a drop of 0,3V...
i put out...
do you know a mosfet without drop voltage??? or minimum... (<0,1V)...
thanks a lot!!!
alex |
SET
Posted: Fri Dec 14, 2007 1:04 pm |
| Use a PNP transistor - your output going low will then switch transistor on, dont forget base resistor! The collector-emitter drop can be very low, usually under 0.1v |
amcfall
Posted: Fri Dec 14, 2007 2:09 pm |
| nicenoise wrote: | yeah,
i put out...
thanks a lot!!!
alex |
I don't have any PN's here but I have used the tiny SOT-23 logic level MOSFETS from Fairchild with great luck. You'd need a P channel, should have a negligible voltage drop (on resistance of milliohms).
Avery |
mcafzap
Joined: 07 Sep 2003 Posts: 46 Location: Manchester, UK
Posted: Sun Dec 16, 2007 1:52 pm |
Have a look at http://www.zetex.com/3.0/pdf/ZXTP25015DFH.pdf
There are several other very low Vcesat devices on this site, all of which have a reasonable gain meaning you don't need much current to drive them. |
Posted: Sun Dec 16, 2007 4:31 pm |
thanks a lot,
i try to find this transistor...
alex |
