evoltech
| Advice on a simple program |
Posted: Mon Dec 10, 2007 4:30 pm |
Hello all I am having trouble getting the simplest of programs to actually do something once it gets on the chip.
I am testing out a PIC16F628A and I can't seem to get any of the pins to "pulse", though everything seems to work fine in MPLAB SIM30 version 3.60.00.00. I am developing with MPLAB IDE 7.60.00.00, compiling with the CCS C compiler 4.0.38, and programming with Quasar electronics PIBmicro programmer version 201106. I have verified that I get a clock pulse on the board but do not see any of the pins on port b pulsing, can you provide any advise?
#include <16F628A.h>
#use fixed_io(b_outputs=PIN_B0,PIN_B1,PIN_B2,PIN_B3,PIN_B4,PIN_B5,PIN_B6,PIN_B7)
int8 toggle = 0xFF;
set_tris_b(0x00);
while (1) {
toggle = ~toggle;
output_b(toggle);
}//while
Posted: Mon Dec 10, 2007 5:34 pm |
You don't need to set fixed i/o mode or TRIS. Just let the compiler
handle it. If you use the CCS i/o functions, the compiler will put in
code to properly handle the TRIS. You don't even have to think about it.
Here's a simple test program that toggles Pin B0. I specified the NOMCLR
fuse, because it's possible that you forgot to put a pull-up resistor on
the MCLR pin. With the NOMCLR fuse, this won't matter. The PIC will
still run the program even without the MCLR pull-up.
If it doesn't work, I would suspect your programmer, or maybe you
don't have a crystal and its capacitors properly connected to the PIC.
#fuses HS, NOWDT, PUT, NOLVP, NOMCLR
output_high(PIN_B0);
output_low(PIN_B0);
rnielsen
Posted: Tue Dec 11, 2007 10:20 am |
In case your crystal might not be functioning properly, you could try using the internal oscillator to see if it works.
| Code: | #include <16F628A.h>
#FUSES NOWDT
#FUSES PUT
#FUSES NOMCLR
#FUSES NOLVP
#FUSES INTRC_IO
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_4MHZ);
output_b(0x00);
output_b(0xFF);
Ronald |
