tong Guest
| Problems with ex.fat32.c and PIC18F4550 |
Posted: Mon Nov 19, 2007 2:37 am |
hi.
I am using 18F4550, and cccs lib ex.fat.c is not working
Now has 2 questions:
1) KINGSTON 1GB SD CARD fat_init the SD Error (SD CARD is OK)
2)be unaware of brand 256MB SD CARD fat_ini the SD ok,but not read the BPB data
ccs compiler version 4.056
I can't understand, why fat_init is Error.....
code:
//These settings are for the CCS PICEEC development kit which contains
//an MMC/SD connector.
#include <18F4550.h>
#device PASS_STRINGS = IN_RAM
//#fuses NOWDT, HS, NOPROTECT
//#use delay(clock=8M)
#DEVICE *=16
#fuses hs,NOWDT,PROTECT,NOLVP,NODEBUG,MCLR,NOVREGEN
#use delay (clock=8000000)
//#use rs232(baud=9600, UART1, errors)
#use rs232(baud=9600,parity=N, xmit=PIN_A3,rcv=PIN_A2,bits=8) //xmit=PIN_C1,rcv=PIN_C0 stream=SW_RS232
#include <stdlib.h> // for atoi32
//media library, a compatable media library is required for FAT.
#use fast_io(c)
#define MMCSD_PIN_SCL PIN_B1 //o
#define MMCSD_PIN_SDI PIN_B0 //i
#define MMCSD_PIN_SDO PIN_C7 //o
#define MMCSD_PIN_SELECT PIN_B3 //o
#include <mmcsd.c>
//FAT library.
#include <fat.c>
/// Useful Defines ///
#define COMMAND_SIZE 10
#define NUM_COMMANDS 11
char buffer[255];
char opt_buffer[255];
char *cmd, *option1, *option2;
int i; // pointer to the buffer
// initialize the FAT
// keep in mind that this will automagically initialize the media
i = fat_init();
if (i)
printf("\r\n\nERROR INITIALIZING FAT\r\n\n");
else printf("\r\n\INITIALIZING FAT OK!\r\n\n");
while(1){;}
//FAT library........
// initialize code
signed int fat_init()
Summary: Initializes global variables that are essential for this library working
Returns: EOF if there was a problem with the media, GOODEC if everything went okay.
Note: This must be called before any other function calls in this library.
int ec = 0;
int
FATs,
Sectors_Per_Cluster;
int16
Bytes_Per_Sector,
Reserved_Sectors,
Small_Sectors;
int32
Hidden_Sectors,
Large_Sectors;
#ifdef FAT32
int32 Sectors_Per_FAT;
#else // FAT16
int16
Root_Entries,
Sectors_Per_FAT;
#endif // #ifdef FAT32
// initialize the media
ec += mmcsd_init();
// start filling up variables
ec += mmcsd_read_data(11, 2, &Bytes_Per_Sector);
ec += mmcsd_read_data(13, 1, &Sectors_Per_Cluster);
ec += mmcsd_read_data(14, 2, &Reserved_Sectors);
ec += mmcsd_read_data(16, 1, &FATs);
#ifdef FAT16
ec += mmcsd_read_data(17, 2, &Root_Entries);
#endif // #ifdef FAT16
ec += mmcsd_read_data(19, 2, &Small_Sectors);
#ifdef FAT32
ec += mmcsd_read_data(36, 4, &Sectors_Per_FAT);
#else // FAT16
ec += mmcsd_read_data(22, 2, &Sectors_Per_FAT);
ec += mmcsd_read_data(28, 4, &Hidden_Sectors);
ec += mmcsd_read_data(32, 4, &Large_Sectors);
#ifdef FAT16
Next_Free_Clust = 2;
#else
ec += mmcsd_read_data(0x3EC, 4, &Next_Free_Clust);
if(ec != GOODEC)
return EOF;
// figure out the size of a cluster
Bytes_Per_Cluster = Sectors_Per_Cluster * Bytes_Per_Sector;
// figure out how long one FAT is
FAT_Length = Sectors_Per_FAT * (int32)Bytes_Per_Sector;
// figure out where the FAT starts
FAT_Start = Reserved_Sectors * Bytes_Per_Sector;
// figure out where the root directory starts
Root_Dir = FAT_Start + (FATs * FAT_Length);
// figure out where data for files in the root directory starts
#ifdef FAT32
Data_Start = Bytes_Per_Cluster + Root_Dir;
#else // FAT16
Data_Start = (Root_Entries * 0x20) + (Bytes_Per_Sector - 1);
Data_Start /= Bytes_Per_Sector;
Data_Start += Reserved_Sectors + (FATs * Sectors_Per_FAT);
Data_Start *= Bytes_Per_Sector;
printf("\r\n Data_Start=%4lu ", Data_Start); //not read the data=0
printf("\r\n FAT_Start =%4lu ", FAT_Start); //not read the data=0
printf("\r\n Root_Dir =%4lu", Root_Dir); // not read the data=0
return GOODEC;
