Receiving RS-232 Data From HyperTerminal (16F877A)
Jomile
PostPosted: Tue Nov 06, 2007 4:56 pm     Reply with quote
I have an 16F877A and MAX233 chip that i am using to communicate with a computer (hyperterminal).
I have no problem sending data to the computer using printf.
The problem I have is when trying to read data back from the computer. For example, in the code below, regardless of what character i get it is not displayed. The output in HT is "nextnextnext" as if there were no character stored in answer.
while(TRUE){
   answer=getc();
   putc(answer);
   printf("next");
Ultimately I want to use the "gets" command so that I can send strings but that did not work so I went to the characters. Is there something wrong with my code? (see below). I have a 20Mhz crystal. 16F877, v. 4.057
main.c
#include "C:\Program Files\PICC\Projects\11-6-07\main.h"
  #include <string.h>
   char answer;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // TODO: USER CODE!!
   printf("Welcome");
   while(TRUE){
   answer=getc();
   putc(answer);
   printf("next");
MAIN.H
#include <16F877A.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPUT                    //No Power Up Timer
#FUSES WRT_50%                  //Lower half of Program Memory is Write Protected
PostPosted: Tue Nov 06, 2007 5:29 pm     Reply with quote
Try a very simple test program:
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
char c;
   c = getc();
   putc(c);
Jomile
PostPosted: Wed Nov 07, 2007 12:09 pm     Reply with quote
Thanks for the code.
I implemented it and still had the same problem. It turned out that the development board that I am using had a resistor between the max chip and the port. I shorted it out and now its fine.
FOLLOW UP:
When I use your test code and the printf function i can send data the hyperterminal. But when I use the PIC Wizard to make a new project my text gets cut off. For example, if i call printf("start") I get "Sta" in HT. I do not have a wdt enabled. See code below.
MAIN.C
#include "C:\Program Files\PICC\Projects\11-7-07\main.h"
  #include <string.h>
   setup_adc_ports(AN0_AN1_AN3);
   setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_4);
   setup_vref(FALSE);
   printf("Start");
MAIN.H
#device adc=8
frequentguest
PostPosted: Wed Nov 07, 2007 12:25 pm     Reply with quote
Your PIC is going to sleep before it finishes transmitting. There is a hidden sleep instruction that is put at the end of main().
Put a while(TRUE); statement after your printf to keep this from happening.
printf("start");
while(TRUE);
