horkesley
| 16 bit i/o |
Posted: Tue Nov 06, 2007 1:32 pm |
I want to output a 16 bit address to access a LCD graphics controller.
If I create a int16 how do I output this on two ports as a 16 bit?
I may need to increase this to a 20 bit address.
Comments please.
Regards,
Stefan _________________ Horkesley Electronics Limited |
Posted: Tue Nov 06, 2007 2:05 pm |
Here is one way to do it:
#include <16F877.H>
#use delay(clock = 4000000)
int16 LCD_data;
#locate LCD_data = 0x06 // LSB on Port B. MSB on Port C.
LCD_data = 0x1234;
Here's the .LST file:
..... LCD_data = 0x1234;
0017: MOVLW 12 // MSB
0018: MOVWF 07 // Port C
0019: MOVLW 34 // LSB
001A: MOVWF 06 // Port B
horkesley
Posted: Wed Nov 07, 2007 8:35 am |
Many thanks PCM Programmer
Horkesley _________________ Horkesley Electronics Limited |
