Orcino
| Struct and bubble sort |
Posted: Fri Nov 02, 2007 9:12 am |
Hi, i am with a problem in struct and bubble sort, with 10 elements this work right but more not right. I write a small code for test, sees below.
Compiler version is 4.058
forgives for my bad English
#include <18F4525.h>
// #DEVICE ICD=TRUE
#FUSES H4 //High speed osc with HW enabled 4X PLL
#use delay(clock = 40 Mhz)
#use FAST_IO(A)
#use FAST_IO(B)
#use FAST_IO(E)
#byte PORT_A=0XF80
#byte PORT_B=0XF81
#byte PORT_E=0XF84
#BIT STD = PORT_B.0
#BIT B_SALVA = PORT_B.4
#BIT B_PROXIMO = PORT_B.6
#BIT B_SAIR = PORT_B.5
#BIT B_APAGA = PORT_B.7
#BIT BUZZER = PORT_B.3
#include <giga_lcd.c>
int8 posicao=0;
// Estrutura
struct SGPSCoord
int32 buffer_latitude;
int32 buffer_longetude;
int distancia;
int16 ponto;
int8 status;
int1 flag_lido;
struct SGPSCoord GPSCOORD[100];
// Funções
void InverteElementos(struct SGPSCoord *pCoordenadas, int nE1, int nE2 );
void BubbleSort( int nQtdElementos, struct SGPSCoord *pCoordenadas );
void preenche_estrutura(void);
void mostra(void);
void calcula_distancias_ordena(void);
// Função principal
lcd_init();
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128); // overflow a cada 840ms
setup_timer_1(T1_DISABLED);
disable_interrupts(INT_RTCC);
disable_interrupts(GLOBAL);
setup_oscillator(False);
set_tris_B(0B11110111); // STD, SALVA , RS232, BOTOES
printf(LCD_PUTC," TESTE ");
preenche_estrutura();
BubbleSort(50,GPSCOORD);
if(!b_proximo)
printf(LCD_PUTC,"\f");
printf(LCD_PUTC,"Posicao %u\r",posicao );
printf(LCD_PUTC,"\nDistancia %u\r",GPSCOORD[posicao].distancia);
posicao++;
// Ordenação
int nBase, nCursor;
for( nBase = 0; nBase < nQtdElementos - 1; ++nBase )
for( nCursor = nBase + 1; nCursor < nQtdElementos; ++nCursor )
if( pCoordenadas[ nBase ].distancia > pCoordenadas[nCursor ].distancia )
InverteElementos( pCoordenadas, nBase, nCursor );
// swap
struct SGPSCoord sTemp;
memcpy( &sTemp, &pCoordenadas[ nE1 ], sizeof( sTemp ));
memcpy( &pCoordenadas[ nE1 ], &pCoordenadas[ nE2 ], sizeof( sTemp ));
memcpy( &pCoordenadas[ nE2 ], &sTemp, sizeof( sTemp ));
// for test
int8 i=0, cont2=0;
for(i=0; i < 50 ; i++)
GPSCOORD[i].buffer_latitude = cont2;
GPSCOORD[i].buffer_longetude = cont2;
GPSCOORD[i].ponto = cont2;
GPSCOORD[i].distancia = cont2;
cont2++;
Posted: Fri Nov 02, 2007 1:34 pm |
Hi, in other small code for test, in 18F452 work right, but in the 18F4525 not work right, see below
18F4525 -------------------------------- 18F452
Valor 0 posicao 0 --------------- Valor 0 posicao 0
Valor 0 posicao 1 --------------- Valor 1 posicao 1
Valor 0 posicao 2 --------------- Valor 3 posicao 2
Valor 0 posicao 3 --------------- Valor 4 posicao 3
Valor 0 posicao 4 --------------- Valor 8 posicao 4
Valor 0 posicao 5 --------------- Valor 9 posicao 5
Valor 1 posicao 6 --------------- Valor 11 posicao 6
Valor 4 posicao 7 --------------- Valor 12 posicao 7
Valor 8 posicao 8 --------------- Valor 13 posicao 8
Valor 9 posicao 9 ---------------- Valor 15 posicao 9
Valor 12 posicao 10 ------------- Valor 19 posicao 10
Valor 19 posicao 11 ------------- Valor 32 posicao 11
Valor 32 posicao 12 ------------- Valor 33 posicao 12
Valor 33 posicao 13 ------------- Valor 34 posicao 13
Valor 34 posicao 14 ------------- Valor 45 posicao 14
Valor 45 posicao 15 ------------- Valor 56 posicao 15
Valor 56 posicao 16 ------------- Valor 65 posicao 16
Valor 65 posicao 17 ------------- Valor 67 posicao 17
Valor 67 posicao 18 ------------- Valor 73 posicao 18
Valor 73 posicao 19 ------------- Valor 100 posicao 19
// #include <18F452.h> // Work Right
#include <18F4525.h> // Nor work
// ***#DEVICE ICD=TRUE
#FUSES HS //High speed osc with HW enabled 4X PLL
#use delay(clock = 20 Mhz)
#use FAST_IO(A)
#use FAST_IO(B)
#use FAST_IO(E)
//#byte PORT_A=0XF80
//#byte PORT_B=0XF81
//#byte PORT_E=0XF84
//#byte DTMF_IN = PORT_A
//#BIT CLK = PORT_E.0 //|
//#BIT DADO = PORT_E.1 //| HT 9200A
//#BIT CE = PORT_E.2 //|
//#BIT STD = PORT_B.0
//#BIT B_SALVA = PORT_B.4 // |
//#BIT B_PROXIMO = PORT_B.6 // | Botoes p/ navegação nas coordenadas salvas
//#BIT B_SAIR = PORT_B.5 // |
//#BIT B_APAGA = PORT_B.7 // |
//#BIT BUZZER = PORT_B.3
#include <giga_lcd.c> // Drive de LCD modificado
#define scl pin_C3 // Define pinos de comunicação com EEPROM
#define sda pin_C4
struct SGPSCoord
int buffer_latitude; // Longetude
int buffer_longetude; // Latitude
int distancia; // Dist. do ponto atual até a coordenada
int ponto; // N. do ponto
int status; // status do eqpt monitorado
int flag_lido; // Indica se coordenada já foi lida
// Funções
void mostra(void);
// Função principal
int cont1;
BubbleSort(20,GPSCOORD); // Ordena pela distancia
for(cont1=0;cont1 < 20 ; cont1++)
printf("\nValor %u posicao %u\r",GPSCOORD[cont1].distancia, cont1 );
// Ordenação
int nBase, nCursor;
// inverte os elementos
// For test
GPSCOORD[0].distancia = 12;
GPSCOORD[1].distancia = 33;
GPSCOORD[2].distancia = 32;
GPSCOORD[3].distancia = 45;
GPSCOORD[4].distancia = 67;
GPSCOORD[5].distancia = 34;
GPSCOORD[6].distancia = 65;
GPSCOORD[7].distancia = 73;
GPSCOORD[8].distancia = 56;
GPSCOORD[9].distancia = 19;
GPSCOORD[10].distancia = 0;
GPSCOORD[11].distancia = 1;
GPSCOORD[12].distancia = 4;
GPSCOORD[13].distancia = 8;
GPSCOORD[14].distancia = 9;
GPSCOORD[15].distancia = 3;
GPSCOORD[16].distancia = 11;
GPSCOORD[17].distancia = 13;
GPSCOORD[18].distancia = 15;
GPSCOORD[19].distancia = 100;
