		| Author | Message |
		| joven
				| I2C Slave |
				|  Posted: Sun Oct 21, 2007 11:39 am |   |
				| Hi
 I'm trying work with i2c slave for my school project.
 I have 18F4685 in software master and 18F2550 in hardware slave.
 First i'm trying with ex_Slave from CCS.
 When the master tell the slave to write the slave the led turn on.
 When the master tell the slave to read the slave don't turn on.
 Master:
  	  | Code: |  	  | #include "pic18.h"
 #use i2c(Master, sda=PIN_D7, scl=PIN_D6)
 #include <pcf8833.c>
 int8 data;
 char escreve[30];
 TRISD=0b00000000;
 TRISB=0b01111110;
 PORTB_RB0=1;
 glcd_init(65);
 glcd_cls(WHITE);
 sprintf(escreve,"ola");
 glcd_text57(5, 3, escreve, 1, BLACK, WHITE);
 // Write the letter 'B' to the slave board.
 i2c_start();
 i2c_write(0xa0);
 i2c_write(0x00);
 i2c_write('B');
 sprintf(escreve,"escreveu");
 glcd_text57(5, 20, escreve, 1, BLACK, WHITE);
 // Read from the slave board and display the data.
 i2c_start();
 i2c_write(0xa0);
 i2c_write(0x00);
 i2c_start();
 i2c_write(0xa1);
 data = i2c_read(0);
 i2c_stop();
 sprintf(escreve,"%c",data);
 glcd_text57(5, 40, escreve, 1, BLACK, WHITE);
 Slave:
  	  | Code: |  	  | #use i2c(SLAVE, SDA=PIN_B0, SCL=PIN_B1, address=0xa0, FORCE_HW)
 BYTE address, buffer[0x10];
 #INT_SSP
 void ssp_interupt ()
 BYTE incoming, state;
 state = i2c_isr_state();
 if(state < 0x80)                     //Master is sending data
 incoming = i2c_read();
 if(state == 1)                     //First received byte is address
 address = incoming;
 if(state == 2)                     //Second received byte is data
 buffer[address] = incoming;
 RB7=1;
 if(state == 0x80)                       //Master is requesting data
 i2c_write(buffer[address]);
 RB6=1;
 void main ()
 enable_interrupts(INT_SSP);
 TRISB=0b00111111;
 RB7=0;
 RB6=0;
 while (TRUE) {}
 The leds is RB6 and RB7
 What I make wrong.
		| PCM programmer
				|  Posted: Sun Oct 21, 2007 1:11 pm |   |
				|  	  | Quote: |  	  | // Write the letter 'B' to the slave board.
 i2c_start();
 i2c_write(0xa0);
 i2c_write(0x00);
 i2c_write('B');
 i2c_stop();
 You need a 'stop' statement.   It's missing from your code.  Add the
 line shown in bold above.
 Also, you don't really need to put in TRIS statements, and you don't
 need to write directly to bits to turn on the LEDs.    If you use
 "Standard i/o" mode and also use the CCS pin i/o functions, then the
 compiler will setup the TRIS for you.   "Standard i/o" mode is the
 default mode of the compiler.   You don't need to specify it.
 Just use CCS functions, such as:
  	  | Code: |  	  | output_high(PIN_B6); output_low(PIN_B6);
 output_high(PIN_B7);
 output_low(PIN_B7);
 Make sure you have pull-up resistors on SDA and SCL, and a ground
 connection between the two PIC boards.   You can use 4.7K ohms for
 the pull-up resistors.
		| joven
				|  Posted: Sun Oct 21, 2007 1:44 pm |   |
				| hi
 I've put the  "i2c_stop();" continue not working.
 The two pics are in the same circuit.
		| PCM programmer
				|  Posted: Sun Oct 21, 2007 1:53 pm |   |
				| 1.  Post your compiler version.
 2.  Post the #include, #fuses, and #use delay() statements for both
 the Master and Slave programs.
 3.  Post the statements which declare 'RB6' and 'RB7'.
		| joven
				|  Posted: Sun Oct 21, 2007 2:36 pm |   |
				| The compiler version is 4.049
 #BYTE PORTB=0xF81
 #BIT RB7=PORTB.7
 #BIT RB6=PORTB.6
 Master:
  	  | Code: |  	  |
 #include <18F4685.h>
 #device adc=8
 #FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
 #FUSES HS
 #FUSES BORV20                   //Brownout reset at 2.0V
 #FUSES NOSTVREN                 //Stack full/underflow will not cause reset
 #FUSES NOWRTD                   //Data EEPROM not write protected
 #FUSES NOIESO                   //Internal External Switch Over mode disabled
 #FUSES NOFCMEN                  //Fail-safe clock monitor disabled
 #FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
 #FUSES BBSIZ1K                  //1K words Boot Block size
 #FUSES NOWRTC                   //configuration not registers write protected
 #FUSES NOWRTB                   //Boot block not write protected
 #FUSES NOEBTR                   //Memory not protected from table reads
 #FUSES NOEBTRB                  //Boot block not protected from table reads
 #FUSES NOCPB                    //No Boot Block code protection
 #FUSES LPT1OSC                  //Timer1 configured for low-power operation
 #FUSES MCLR                     //Master Clear pin enabled
 #FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
 #include "pic18.h"
 //See the program below which shows some corrections for your code.
 //The following program works OK with EX_SLAVE.C
 int8 data;
 char escreve[30];
 TRISD=0b00000000;
 TRISB=0b01111110;
 PORTB_RB0=1;
 glcd_init(65);
 glcd_cls(WHITE);
 i2c_start();
 i2c_write(0xa0);
 i2c_write(0x00);
 i2c_write('B');
 i2c_stop();
 i2c_start();
 i2c_write(0xa0);
 i2c_write(0x00);
 i2c_start();
 i2c_write(0xa1);
 data = i2c_read(0);
 i2c_stop();
 Slave:
  	  | Code: |  	  |
 #include <18F2550.h>
 #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOPBADEN,WRTB,MCLR,NOCPD,NOWRTC
 #use delay(clock=48000000)// full speed USB device
 // START OF bootloader definition
 #define LOADER_END   0x7FF
 #define LOADER_SIZE   0x6FF
 #build(reset=LOADER_END+1, interrupt=LOADER_END+9)
 #org 0, LOADER_END {} // nothing will replace the bootloader memory space
 // END OF bootloader definition
 #include "picram18Fx550.h"
 #INT_SSP
 address = incoming;
 RB7=1;
 RB6=1;
 void main ()
 TRISB=0b00111111;
 RB7=0;
 RB6=0;
 while (TRUE)
		| joven
				|  Posted: Tue Oct 23, 2007 12:08 pm |   |
				| can be not working because of fuses? |  |
		| robotam
				|  Posted: Mon Nov 19, 2007 9:53 am |   |
				| i2c_start(); i2c_write(0xa0);
 i2c_write(0x00);
 i2c_start();
 i2c_write(0xa1);
 data = i2c_read(0);
 i2c_stop();
 I dont understand why   i2c_write(0xa1);   what this value 0xa1 means?
		| joven
				|  Posted: Mon Nov 19, 2007 2:53 pm |   |
				| is the mode you read/write, can easly find a example on I2C eeprom |  |
		| kender
				|  Posted: Fri Jan 11, 2008 6:09 pm |   |
				|  	  | robotam wrote: |  	  | I dont understand why   i2c_write(0xa1);   what this value 0xa1 means? |
 0xA1 = 0xA0 | 0x01, where 0xA0 is the I2C address of the slave defined in the #use i2c(slave, ... , address=0xA0), and 0x01 is a R/W# bit.
 Read the label, before opening a can of worms.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
