Milhaus
| fat.c , signed int and EOF |
Posted: Sat Oct 20, 2007 11:22 am |
could you explain me why functions like fatgetc in FAT.c driver implementation of CCS compiler return signed int ( int8 ) instead signed int ( int16 ) like ANY other standart ANSI compilers ? It is impossible to detect from these functions end of file, because 8bit value cannot contain 8bit binary value and EOF.Detecting EOF from the stream->Flags value is not too much compatible with other C compilers.Why you dont use the standart functions ? It is due any code optimalization ?
Milos
signed int fatgetc(FILE* stream)
char ch; // character read in
// check to see if the stream has proper permissions to read
if(stream->Flags & Read)
// when the number of bytes until eof hit zero, we know we are at the end of any file
if(stream->Bytes_Until_EOF == 0)
stream->Flags |= EOF_Reached;
return EOF;
Posted: Sun Oct 21, 2007 8:15 am |
| Quote: | | could you explain me why functions like fatgetc in FAT.c driver implementation of CCS compiler return signed int ( int8 ) instead signed int ( int16 ) like ANY other standart ANSI compilers ? | 1) This is a forum for users of the CCS compiler, the people of CCS don't monitor all messages (see the textbox on the top-right of every page of this forum). So for specific library internal questions this forum is not the right place.
2) The CCS compiler is not ANSI, it is a mixture of K&R, ANSI and C++ with a flavour of PIC specific add-ons.
3) ANSI does _not_ define an integer as 16 bit! This is left to the compiler builder to decide, for optimal code efficiency often based on the width of the processor's data bus (8 bits on a PIC, 16 bits on a 80286, 32 bits on a Pentium, etc). Using the #type specifier you can change the size of the compiler's data types if you want to.
Please keep in mind that the CCS supplied FAT driver is very new and you are one of the first user's. It is possible there are bugs and missing features. Please communicate your comments to support@ccsinfo.com so they will learn what we users think is important.
Note: I had a quick look at the FAT driver and I think you have a valid point. The CCS code is mixing signed and unsigned int8 variables, making it impossible to distinguish between a binary 0xFF in the file or an EOF (-1) being returned. |
