| deepakomanna
				| how to allocate eeprom memory bitwise |
				|  Posted: Thu Oct 11, 2007 1:16 am |   |
				| Dear Sir, i am using 16f913, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.
 i am writng incremented number(0 to 999999) in EEPROM.
 so,
 1)if the number is between 0 to 255(FF) i have to allocate zero location
 2)if number is between 256 to 65025(FF * FF) i have to allocate zeroth & 1st location
 & 3)if number is between 65025 to 999999 (FF * FF * FF) i have to allocate zeroth & 1st,2nd location
 Here max. number is 999999 & if i am trying to use 3rd location the length of
 number will be FF * FF * FF == (16581375).
 So, how can i allocate memory space as bitwise
 i.e. if 4 bit length is 16,
 10 bit length is 1024
 20 BIT number length is 1048576  etc...
 can anybody suggest the method to allocate the memory like this,
 Thank You,
 With Best Regards,
 Deepak.
