ChrisL
Is this PIC C-18 Compiler Structure Possible in CCS...? |
Posted: Sat Sep 15, 2007 8:42 pm |
I am converting the J1939 PIC-18 Complier code. There is a (Structure inside of a Union) in PIC-C;
Code: | union J1939_MESSAGE_UNION {
struct {
unsigned int PDUFormat_Top : 3; // This needs pre and post processing.
unsigned int DataPage : 1;
unsigned int Res : 1;
unsigned int Priority : 3;
unsigned char PDUFormat; // CA should use only PDUFormat.
unsigned char PDUSpecific;
unsigned char SourceAddress;
unsigned int DataLength : 4;
unsigned int RTR : 4; // RTR bit, value always 0x00
unsigned char Data[J1939_DATA_LENGTH];
unsigned char Array[J1939_MSG_LENGTH + J1939_DATA_LENGTH];
#define GroupExtension PDUSpecific
#define DestinationAddress PDUSpecific
typedef union J1939_MESSAGE_UNION J1939_MESSAGE; |
That I can't get to work in CCS. Does anybody know how to code this function..??? _________________ Thank you,
Chris |
Posted: Sat Sep 15, 2007 10:04 pm |
Quote: | I can't get to work in CCS |
Give specific details.
1. Post your compiler version.
2. Post your PIC.
3 Post any compiler error messages.
4 Post a small test program, that shows improper operation.
5. Also, provide #define statements for these two constants:
Quote: | J1939_DATA_LENGTH
J1939_MSG_LENGTH |
Posted: Sun Sep 16, 2007 8:06 am |
ChrisL,
The CCS compiler does not support unnamed types in a union, this means you will have to add a name to the first struct in the enum.
It seems like the High-Tech compiler is suffering from the same limitation as I found a ported version which has the required changes: http://www.htsoft.com/forum/all/showflat.php/Cat/0/Number/24552/Main/20677
Code: | #define J1939_MSG_LENGTH 5
#define J1939_DATA_LENGTH 8
struct {
} Msg; <<----------------- Add this for CCS as well.
A side note:
Unnamed union members are a part of the ANSI/ISO 9899-1999 standard. CCS provides a comparison to the older 1990 version of the standard in http://www.ccsinfo.com/downloads/ansi_compliance.pdf. Too bad I can not find a copy of the 1990 standard on the internet so I can not check the CCS compliance statements. |
ChrisL
Posted: Sun Sep 16, 2007 8:14 pm |
FINALLY, I figured out how to do this in CCS... Here is how it works...
Code: | In CCS here is a Structure inside of a Union...
/****************************Messaging*******************************************/
struct J1939_MESSAGE_STRUCT
unsigned int PDUFormat_Top:3; // This needs pre and post processing.
unsigned int DataPage:1;
unsigned int Res:1;
unsigned int Priority:3;
unsigned int DataLength: 4;
unsigned int RTR: 4; // RTR bit, value always 0x00
struct J1939_MESSAGE_STRUCT Msg;
It's aliased like this..
J1939_MESSAGE OneMessage;
It's addressed like this; OneMessage.Msg.SourceAddress
With a pointer like this; MsgPtr->Msg.PDUFormat_Top
After 5, 20 hour days working on the conversion I have functional J1939 code converted from the Library that Microchip has on their web site.
Sometimes you just need to stop and ask the question to get back on the right track...
ckielstra - I like your solution better. I will give it a try to make my code simpler...
Thanks to all that responded... _________________ Thank you,
Chris |
Posted: Tue Sep 25, 2007 7:58 am |
I asked CCS to add support for unnamed members for struct and unions. This is part of the ANSI/ISO 9899-1999 specification (and maybe in the 1990 version also).
Sept 24 I received an email saying this is implemented in the next release (4.058).
The new feature allows you to write code like: Code: | union foo
struct
int a;
int b;
}; <-- note: no name here, makes it an anonymous structure.
char c;
} bar;
char c;
bar.a = c; /* 'a' is a member of the anonymous structure
located inside 'bar' */ |
A nice example for this new feature is when converting bytes to words and vice versa.
Old situation Code: | union HL
int16 L;
struct
int8 low;
int8 high;
} hl;
usage:
union HL var1;
var1.L = 50000; // as an INT16
var1.hl.high = 195; // access the high byte
var1.hl.low = 80; // access the low byte
New situation Code: | union HL
int16 L;
struct
int8 low;
int8 high;
}; // no name
usage:
union HL var1;
var1.L = 50000;
var1.high = 195; // Note the easier notation
var1.low = 80;
ChrisL
Posted: Tue Sep 25, 2007 8:35 am |
ckielstra,
That's great...! _________________ Thank you,
Chris |
