Can you generate your own complier warnings ?
nurquhar
PostPosted: Mon Sep 10, 2007 4:23 am     Reply with quote
Is there a way to generate compliler warnings ? Question
I tried using #ERROR like below but its not accepted. Can't find something like #warnt in help file either. I just want to send myself a reminder that I have compiled for use with ICD and thus I should turn the option off before releasing the code. I have PCM3.249.
// Running in ICD mode ?
#if getenv("ICD") == 1
#define __ICD__
#endif
#ifdef __ICD__
#ignore_warnings 119
#error Compiled For ICD
#endif
Humberto
PostPosted: Mon Sep 10, 2007 5:25 am     Reply with quote
#if getenv("ICD")
#else
#error Compiled For Releasing
#endif
Humberto
nurquhar
PostPosted: Mon Sep 10, 2007 6:55 am     Reply with quote
Dear Humberto
I am afraid your version does the same as mine. ie the compiler will not let you ignore code 119 and the #error stops compilation rather than carrying on as if only a warning had been encoutered. I got the following errors for your code :
*** Error 119 "N:\Projects\RonHaselden\WaterMusic\System\PIC\SysLinRGB_01\SysLinRGB_01.c" Line 27(7,26):  Compiled For ICD
*** Error 103 "N:\Projects\RonHaselden\WaterMusic\System\PIC\SysLinRGB_01\SysLinRGB_01.c" Line 28(17,22): Constant out of the valid range  119 is not 200..299
Neil
Humberto
PostPosted: Mon Sep 10, 2007 8:22 am     Reply with quote
Preprocessor #ERROR enable you to generate Compiler ERROR, not Compiler WARNIG.
I just copied and pasted your code. Warning 119 as the Compiler says, does not exist.
Humberto
nurquhar
PostPosted: Mon Sep 10, 2007 9:26 am     Reply with quote
Thats because my question was : "Can you generate your own complier warnings ?", ie not errors !
Humberto
PostPosted: Mon Sep 10, 2007 10:02 am     Reply with quote
At compiling time I guess you have not options, but at power up time, you could do something like this:
// Insert this code after init procedure and before main()
#if getenv("ICD")
printf("*** Warning ICD Enabled ! ***");
#else
printf("Release Version #1.%02d", version);
#endif
Humberto
nurquhar
PostPosted: Mon Sep 10, 2007 11:09 pm     Reply with quote
Unfortunaly my project requires that all 250 PIC units will be using the serial port to connect to my RS485 multi drop netowrk. So they are only supposed to "speek" when "spoken" to. Also I don't want to program 250 units and then realise, oops I forgot to turn ICD option off.
Thanks for your thoughts. It was more in hope than expectation that user warnings were possible.
Neil
PostPosted: Tue Sep 11, 2007 3:35 am     Reply with quote
I do agree the possiblity to define your own warning messages can be a nice feature. I don't think in the current CCS versions this is possible, but why don't you send CCS a message requesting this feature? It's not a big issue, so you might be lucky and they will put it in soon.
PostPosted: Thu Feb 12, 2009 7:02 am     Reply with quote
Hi
Try pre processor directive
#error/warning Text
cheers Simon
PostPosted: Thu Feb 12, 2009 8:31 am     Reply with quote
Reading the current manual Page 139 shows the
preprocessor directive: #WARNING
