kein
| adc pic16f877a not has stopped working! |
Posted: Fri Sep 07, 2007 8:10 am |
The following codes prints zero even when Vref+ is set to vdd(5v) and vref- set to ground(vss). why isn't it working? any idea?
| Code: | #include <16F877A.h>
#device *=16
#device adc=10
#FUSES HS //High speed Osc (> 4mhz)
#include <KBD.C>
#include <ctype.h>
#include <float.h>
#include <math.h>
#include <string.h>
#include "LCD.c"
long int adcValue; // 16-bit storage for ADC reading
lcd_init();
setup_adc_ports(AN0_AN1_AN4_AN5_VREF_VREF);
setup_adc(ADC_CLOCK_DIV_32);;
setup_adc(ADC_OFF);
lcd_goto_xy(1,1); // Type some characters and backspace over them.
lcd_put_c(" X Y Z");
delay_Ms(1000);
// TODO: USER CODE!!
//AccelCalibrateXYZ();
set_adc_channel(0); // select the required channel
delay_us(10);
adcValue =read_adc();
lcd_gotoxy(13,2);
printf(lcd_putc, "%Lu ", adcValue);
delay_ms(200);
//return 0;
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
Posted: Fri Sep 07, 2007 8:23 am |
try commenting out the following line in your code: | Code: | | setup_adc(ADC_OFF); |
That might solve your problem |
kein
| it did solve the problem |
Posted: Fri Sep 07, 2007 9:57 am |
| it did solve the problem; thanks |
