Can I write a function in mplab and use it in the CCS?
asmallri
Joined: 12 Aug 2004 Posts: 1660 Location: Perth, Australia
Posted: Sun Sep 02, 2007 7:11 am
MPLAB is an IDE. You can install CCS under MPLAB using the MPLAB environment to develop you CCS application. The source code is identical to that produced in the CCS IDE and is interchangable between the two development environments.
If you actually meant can you exchange between CCS C and Microchip C18 then you would need to "port" between the environments. This is not trivial. _________________ Regards, Andrew
