16F688 and 16f627A issues
ralph79
PostPosted: Wed Aug 29, 2007 8:59 am     Reply with quote
I've been working with CCS compiler V4.0.038 and I have a very strange problem. I have basically the same code as you can you above for the 627A and for the 688. But with the 16F627 in the rs232 port I receive the same characters I send. But with the 688 the characters are all wrong. Does anybody know why is this happening?
Code for 627A
#include <16F627A.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOMCLR, NOBROWNOUT, NOCPD, PUT
#define max_buf_length      10
#use delay(clock=8000000)
#use rs232(baud=1200, parity=N, xmit=PIN_B2, rcv=PIN_B1, bits=8, errors)
int8 rcv_data[max_buf_length] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
int8 rcv_pointer = 0;
int8 pos_eeprom = 0;
short int values_rcv = 0;
#int_RDA   // rs232 receive data available
void RDA_isr(void)
   int8 ch = 0;
   ch = getchar();
   rcv_data[rcv_pointer++] = ch;            // store data
   if (rcv_pointer == 10)
      values_rcv = 1;
   int8 i = 0;
   port_b_pullups(TRUE);
   set_tris_b(0x01); // PIN_B1 as input
   setup_vref(FALSE);
   disable_interrupts(INT_RDA);
   enable_interrupts(INT_RDA);
   while (1)
      if (values_rcv == 1)
         for (i = 0; i < rcv_pointer; i++)
            write_eeprom(pos_eeprom++, rcv_data[i]);
            rcv_data[i] = 0;   // cleaning the buffer
         pos_eeprom = pos_eeprom + 2;
         values_rcv = 0;   // reset variables
         rcv_pointer = 0;
Code for 688
#include <16F688.h>
#device *=16
#device adc=8
#fuses INTRC_IO, NOWDT, NOPROTECT, NOMCLR, NOBROWNOUT, NOCPD, PUT, NOIESO, NOFCMEN
#use rs232(baud=1200, parity=N, xmit=PIN_C4, rcv=PIN_C5, bits=8, errors)
void RDA_isr(void)
   int8 ch = 0;
   ch = getchar();
      values_rcv = 1;
   int8 i = 0;
   port_a_pullups(TRUE);
   set_tris_c(0x20); // PIN_C5 as input
   setup_adc(ADC_OFF);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   setup_oscillator(OSC_8MHZ);
   while (1)
         rcv_pointer = 0;
Any help will be appreciate
Thanks in advance
SET
PostPosted: Thu Aug 30, 2007 9:04 am     Reply with quote
I'm guessing you tried this in case the compiler wasn't setting Rx as an input? Shouldn't be required..
Are you missing some code? Your code puts the Rx'ed chars in EEPROM, so maybe the problem lies there?
ralph79
PostPosted: Thu Aug 30, 2007 9:21 am     Reply with quote
Thanks for your response.
The set_tris_a was my ultimate test. I know that it shouldn't be required but ... I've already try everything.
This code is just a very small part of complex program.
I receive the chars from a RF receiver and, for a test, I save them to the eeprom. With this I want to know if there are any differences between the characters that I send and characters I receive during the time. With the 16F627A I don't have any trouble. But with the 688 I can't get it to work properly.
Is there any other initialization or function that I need to put in my code do get this work? Or in other words what I missed?
