zilog Guest
Posted: Mon Aug 13, 2007 3:10 am |
Series resistor on osc out to xtal did not help.
470 ohm seem "right", at about 10k it fail to start.
The waveform got nicer, but the program still fail similarly.
What is more frightening is that we found other places in the program where if-statements fail sometimes. Iĺl see if i can get a REAL-ICE here ASAP to trace this mystery! |
kevcon
Joined: 21 Feb 2007 Posts: 142 Location: Michigan, USA
Posted: Mon Aug 13, 2007 8:31 am |
You might want to look at the assembly to see if the compiler is doing something strange.
This was compiled with 4.038 for a pic18F65J10 part
Look at where cc gets set to 0x0007, what are the extra mov's for?
struct mystruct {
unsigned int8 aa;
unsigned int16 bb;
unsigned int32 cc;
struct mystruct data, *data_ptr;
void main( void )
unsigned int32 myvar = 0;
data_ptr = &data;
data_ptr -> cc = 0x0007;
data_ptr -> cc = myvar;
41: unsigned int32 myvar = 0;
001C 6A0E CLRF 0xe, ACCESS
001E 6A0F CLRF 0xf, ACCESS
0020 6A10 CLRF 0x10, ACCESS
0022 6A11 CLRF 0x11, ACCESS
42:
43: data_ptr = &data;
0024 6A0D CLRF 0xd, ACCESS
0026 0E05 MOVLW 0x5
0028 6E0C MOVWF 0xc, ACCESS
44:
45: data_ptr -> cc = 0x0007;
002A 0E03 MOVLW 0x3
002C 240C ADDWF 0xc, W, ACCESS
002E 6EE9 MOVWF 0xfe9, ACCESS
0030 0E00 MOVLW 0
0032 200D ADDWFC 0xd, W, ACCESS
0034 6EEA MOVWF 0xfea, ACCESS
0036 52EE MOVF 0xfee, F, ACCESS <<<<<<<<<<<<<<<<
0038 52EE MOVF 0xfee, F, ACCESS <<<<<<<<<<<<<<<<
003A 6AEC CLRF 0xfec, ACCESS
003C 52ED MOVF 0xfed, F, ACCESS <<<<<<<<<<<<<<<<
003E 6AEF CLRF 0xfef, ACCESS
0040 52ED MOVF 0xfed, F, ACCESS <<<<<<<<<<<<<<<<
0042 6AEF CLRF 0xfef, ACCESS
0044 52ED MOVF 0xfed, F, ACCESS <<<<<<<<<<<<<<<<
0046 0E07 MOVLW 0x7
0048 6EEF MOVWF 0xfef, ACCESS
46:
47: data_ptr -> cc = myvar;
004A 0E03 MOVLW 0x3
004C 240C ADDWF 0xc, W, ACCESS
004E 6EE9 MOVWF 0xfe9, ACCESS
0050 0E00 MOVLW 0
0052 200D ADDWFC 0xd, W, ACCESS
0054 6EEA MOVWF 0xfea, ACCESS
0056 C00E MOVFF 0xe, 0xfef
005A C00F MOVFF 0xf, 0xfec
005E C010 MOVFF 0x10, 0xfec
0062 C011 MOVFF 0x11, 0xfec
Mogge
kevcon
Posted: Tue Aug 14, 2007 6:51 am |
level 9
I tried level 10, no effect
Level 11 didn't have any effect on it other than adding a subroutine to init the FSR0 regs |
Mogge
Posted: Wed Aug 15, 2007 7:03 am |
To get back to our problemthe thread is really about:
We experience if-statements giong wrong, and functions returning impossible values, but they are OK inside the function.
We are anxiously waiong for the REAL-ICE-debugger to arrive.
Meanwhile below is a sum-up of themost important things we have done.
_____Technical details for anyone interested____
We have eliminated any cirquit layout, EMC, and clocking errors, and
studied the compiler generated assembler.
The assembler this compiler (CCS) generates is a lot less efficient than
expected, and it sometimes do some things in a really clumsy way, but we have yet not found anything plain wrong. We have tried different versions of the compiler, and different optimisation levels.
As we have a UART we use to send debug to a test terminal, and by that we have spotted that functions evaluate correctly, but the calling routine sometimes, very rarely get a completely different value. We have by variable sampling before and after code lines also spotted if-statements evaluate wrong. Even with all interrupts disabled, and all hardware environment such as supply and clock checked very thoroughly. This is really hair pulling!
We also have tried moving the code to to other adress: same problem.
And it happens in more than one place in the code.
What is currently even more strange is that the problem seem to went away
after a recent work on a completely unrelated part of the program. This is
NOT good as we will probably have the problem back at any random time we
implement more functiojnality. And we need to have the problem to cath it.
So we keep hunting.
Yes we have read the erratas and datasheet may times...
__On the hardware side we have tried:
POWER SUPPLY
o Although we could not scope any supply voltage noise, we improved the
already good decoupling with more capacitors of different technologies, and
damping R-C network.
o We tried medium, max and min operating voltage.
OSCILLATOR
We learned from forum that some early chips in this family could have problem with the PLL oscillator if not using series resistor to drive the crystal, so we also experimentet with this.
LAYOUT
Careful layout of power and oscillator, etc - we are no beginners...
OTHER CHIP INDIVIDUAL
o Another microcontroller of same type is soldered on top of the "old". They have all pins in parallel except reset, and crystal cirquit. So by a switch
we can at any time select which to run by holding the other in reset.
SHIELDING
o all sorts of shielding, we already had power plane under the uC, then also
GND connected copper taped on top of processor and bottom of board.
PHYSICAL MOVE
o Moved it from DriveLPI; elongated connections to DriveLPI and put the board
30cm away in a metal box, and all cable through noise suppression toriods
REDUCE SWITCING POWER NEARBY
o We avoid using the the brake switch in this board
o We supply power through battery instead of DriveLPI
o We disconnected motor from DriveLPI
o MICROSCOPE
We borrowed a good stereo microscope to study all solder joints
o HF oscilloscope
Studied oscillator waveform
Supply noise
o Digital sampling oscilloscope
...is another tool used
And lots of tests...
NONE of the hardware changes have had any notable effect!
Now we focus on compiler, change processor, and keep looking over our own code although we ruled it out for th basic problem, we improve parts slowly.
The other microcomputer in this project, the panel and measurement unit in the handle, is and have been working like a charm all time, no problem whatsoever. We there used the same compiler but a smaller sister to the main microcontroller. |
kevcon
Posted: Wed Aug 15, 2007 7:33 am |
Have you looked at the .sym file, there have been cases where the compiler is re-using memory locations that shouldn’t be re-used?
I had a similar problem with if statements like this not working correctly.
if ( test )
do something....
And fixed it by adding braces
if ( test ) {
do something....
But from your earlier post I see you tried this. |
Posted: Wed Aug 15, 2007 3:46 pm |
| Quote: | What is currently even more strange is that the problem seem to went away
after a recent work on a completely unrelated part of the program. | This is a very strong sign indicating memory corruption. Memory corruption can be caused by hardware problems (chip errata, power supply glitches, etc.) but in 99% of the cases are caused by software errors like buffer overflows, uninitialized pointers, compiler errors, etc.
It might be a compiler bank switching problem. Can you use the email function of this forum to send me the list file for the ChainFUCommunicationRoutine() ? |
Mogge
Posted: Thu Aug 16, 2007 11:13 am |
ckielstra, thank you.
We will send the file tomorrow. (the one from the program verison that have problems in that part... )
We now recieved the REAL-ICE debugger, which we will learn and hope to catch something interesting with.
Microchip support have suggested we try their C18 compiler, but I think there is a lot of work to port the code. We have not used many pre-built functions, but some.
Anybody knows more about porting? |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Fri Aug 17, 2007 12:23 pm |
Have you sent this to CCS tech support?
Which if fails? _________________ I came, I saw, I compiled. |
Darren Rook
Posted: Mon Aug 20, 2007 7:55 am |
If you want official CCS support on this matter you need to e-mail me all your files (sources, list files, sym file, etc). _________________ I came, I saw, I compiled. |
zilog
Posted: Mon Aug 20, 2007 10:29 am |
| Darren Rook wrote: | | If you want official CCS support on this matter you need to e-mail me all your files (sources, list files, sym file, etc). |
Hi Darren,
An email with the latest state of the project is on its way.
Best regards
Daniel Nilsson |
Mogge
