Tuga Guest
| mplab error |
Posted: Wed Aug 08, 2007 8:07 am |
Dear all,
I am using mplab and my compiler ccs indicates an error in the following line:
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xc, // Display on
1, // Clear display
6 // Increment cursor
the message error is:
*** Error 128 "C:\...\flex_lcd.c" Line 28(1,42): A #DEVICE required before this line
I am using PIC18F4455 and LCD 16x2.
How I can decide this problem?
Thanks |
axmanjr
Joined: 07 Aug 2007 Posts: 25 Location: Las Vegas, NV
Posted: Wed Aug 08, 2007 9:45 am |
It seems to me that you're missing a predecessor (sp). I'm not sure what you're trying to do with your code, but if you look at the ccs manual (pg 38), it explains about the #device protocol:
#device CHIP OPTIONS
CHIP: the name of a specific processor (like: PIC18F4455)
OPTIONS: qualifiers to the standard operation of the device.
Page 38 and 39 give a bunch of valid OPTIONS, which is probably what the compiler is looking for with your code |
Tuga Guest
| Thanks |
Posted: Thu Aug 09, 2007 9:29 am |
Debtor for the aid.
I decided the problem. I simply changed projecto for a new folder without modifying the code, and works.
thanks for help. |
