Chris b Guest
| SPI problem - PIC16f877a to MCP2515 |
Posted: Fri Jun 01, 2007 10:38 am |
i'm having a problem when using an SPI interface to communicate between a PIC16f877a and an MCP2515 CAN controller, using the CCS pic C compiler.
The following code is supposed to test the SPI interface by writing to a register in the MCP 2515, then reading it back. the problem is that some of the bits read back are different from those sent. I've put in a function to clear the BF bit (as suggested in the PIC16f877a datasheet) before the read takes place, but it doesnt make any difference.
while (TRUE)
for (k=0; k<=0xFF; k++)
output_low(CAN_CS); //begin SPI comms
spi_write(WRITE); //send the write instruction
spi_write(0x34); //address of a register to test reading and writing
spi_write(k); //send the data
output_high(CAN_CS); //SPI comunication finished
restart_wdt(); // restart the watchdog timer
delay_ms(50); //wait for 50ms before the read occurs
output_low(CAN_CS); //start another round of SPI comms
spi_write(READ); //send the read instruction
spi_write(0x34); //read from the register the data was written to
clear_BF(); //clear bit BF before reading the input data
i = spi_read(0x00); //read the value of the register into i
i = i ^ k ; //XOR together to make bits where an error has happened = '1'
output_d(i); //output the errors onto LEDs for visual inspection
delay_ms(50); //wait for 50ms before going round the loop again
the SPI port on the pic is configured as follows:
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_64 | SPI_XMIT_L_TO_H | SPI_SAMPLE_AT_END);
i've tried with various clock pre-scalers, sampling in the middle instead of the end, and opposite clock polarity, all to no avail.
i know the CAN controller is getting at least some SPI instructions, as i am able to change it's clock out pre-scaler via SPI successfully.
any suggestions? |
Posted: Fri Jun 01, 2007 1:26 pm |
Try the test program shown in this thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=18539
Note that he initially has a problem with the SPI interface
because he's using SPI Mode 2, and the MCP2515 data sheet
says that it must use mode 0 or 3. Later in the thread, he
changes his setup_spi() statement to use SPI mode 3.
It's easier to setup the correct SPI mode if you use these definitions.
#define SPI_MODE_0_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_0_1 (SPI_L_TO_H)
#define SPI_MODE_1_0 (SPI_H_TO_L)
#define SPI_MODE_1_1 (SPI_H_TO_L | SPI_XMIT_L_TO_H)
Edit his code to use mode 0 or mode 3 and then try it.
Also change the #define statements for the \Reset and \CS
pins to match your hardware. |
Chris B Guest
Posted: Mon Jun 04, 2007 3:22 am |
| will give it a try, thanks |
chris b Guest
Posted: Mon Jun 04, 2007 8:09 am |
think i've got it sorted now, the other threads with explanation of modes etc were very useful.. a l
but what seems to have solved my problem was to specifically set TRIS<C> such that SDI pin of the PIC is configured as an input - something which the data sheet claims you don't have to do.
Thanks again for the help - a veritable resource of info this forum
aswinthomas Guest
| mcp2515 |
Posted: Tue Jul 24, 2007 7:33 am |
hi
i am also suffering with the same problem
i also want to set mode0,0 or mode1,1 as
per the data sheet ,i am doing this in assembly
can u explain me that which bit must be set
for it,i will be thankfull for it
aswin |
Posted: Tue Jul 24, 2007 7:58 am |
// MOTOROLA | MICROCHIP | CCS
// SPI Mode 0,0 | CKP = 0, CKE = 1 | SPI_L_TO_H | SPI_XMIT_L_TO_H
// SPI Mode 0,1 | CKP = 0, CKE = 0 | SPI_L_TO_H
// SPI Mode 1,0 | CKP = 1, CKE = 1 | SPI_H_TO_L
// SPI Mode 1,1 | CKP = 1, CKE = 0 | SPI_H_TO_L | SPI_XMIT_L_TO_H
ASWIN Guest
| MCP2515 |
Posted: Wed Jul 25, 2007 12:22 am |
HI CKIELSTRA,
THANKS for ur code ,i tried it in my code
but its not working i dont no wats the
mistake i here attched my code can u
tell me were the mistake or if possible
post me a code for spi_initialisation and
one for r/w for mcp2515 once again thanks
CS=0;
asm("nop");
SSPBUF=0B00000010;//write inst
SSPBUF=0X30;
SSPBUF=0b11100111;//data
CS=1;
delay(25000);
CS=0;
SSPBUF=0b00000011;//read inst
asm("nop");
SSPBUF=0X30;
asm("nop");
asm("nop");
HOLDER=SSPBUF;
CS=1;
asm("nop");
asm("nop");
asm("nop");
if(HOLDER==0b11100111)
PORTA=0X3F;
RA0=1;
void spi_interface (void)
TRISC =0b00010000; // setting SDO,SDI,SCK pins.SDI must set as input
//SSPSTAT
STAT_SMP=1; //Sample bit.Input data sampled at middle of data out put time
STAT_CKE=1; //SPI clock edge select. data trans on rising edge of SCK.case CKP=1.
//SSPCON
CKP=1; //Clock polarity select bit.Idle state of clock is a high level
SSPEN=1; //Synchronous serial port enable bit.
SSPM3=0; //SSPM3:SSPM0- Synchronous serial port mode select bit
SSPM2=0;
SSPM1=0; //SPI master mode, Fosc/4.
SSPM0=0;
aswin thomas |
Posted: Wed Jul 25, 2007 1:38 am |
| Quote: | | i also want to set mode0,0 or mode1,1 | I gave you the correct settings, then why do you set CKE=CKP=1 ? These are the settings for mode 1,0.
| Code: | | STAT_SMP=1; //Sample bit.Input data sampled at middle of data out put time | The text and the program code do not match.
Also change to SMP=0 for a correct setup.
| Code: | SSPBUF=0B00000010;//write inst
SSPBUF=0X30;
SSPBUF=0b11100111;//data | After each write to the SPI transmit buffer you will have to give the processor some time to transmit the data, for example by waiting in a loop until the BF flag gets set.
Sorry, I can't give you a complete driver. I don't know the mcp2515 and this forum is for the CCS C compiler, your compiler is different. I don't know how to do it for your compiler, best is to go to their website. |
aswin Guest
| mcp2515 |
Posted: Wed Jul 25, 2007 2:18 am |
hi,
sorry man its of some posting
mistake i post my older code
once again sorry and thank u
for ur reply by
aswin |
