cyberant
| changed from 16f877 to 18f4525 and stepper doesn't work |
Posted: Tue Jul 24, 2007 4:38 am |
I changed from PIC 16f877 to 18f4525 and i have the same code but my stepper doesn't work anymore.
Ive measured the frequency --> its much to high on the 18f4525
The Code works on the 16f + stepper works - but of cource with an other .h file - can this be anything with the internal oscilator or something?
#include "main.h"
unsigned long i;
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
Setup_Oscillator(OSC_PLL_OFF);
// TODO: USER CODE!!
puts("Serial works");
output_low (PIN_D6); //schaltet Motor ein
output_low (PIN_B2); //drehrichtung
//for (i=0;i<1000;i++)
while (true)
output_high(PIN_B1);
delay_us( 400 );//400 = standart
output_low(PIN_B1);
delay_us( 400 );
my main.h file:
#include <18F4525.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#use delay(clock=12000000)
Posted: Tue Jul 24, 2007 5:06 am |
Before trying anything else, get rid of the XINST fuse. The CCS compiler _does not support the use of this fuse_. Wth it enabled, the odds are the code will not work properly. It is present, in case you need the instructions for soething else, but (stupidly), on some chips seems to default to being turned on...
You may well find this is all that is wrong.
cyberant
Posted: Tue Jul 24, 2007 5:30 am |
AH THANK YOU VERY MUCH
that was the solvation.
The Projektwizzard created this [censored]...
Now everything works fine :-) |
