Ringo42
| More I2C woes |
Posted: Sun Jul 22, 2007 2:06 pm |
I have a master and a slave, both identical boards. If I read a value from the slave, it is correct. But if I write to the slave, then read, all reads are returning -1's. I have the Slave hard coded to return a 42 so it has to be sending the right thing. The slave also blinks leds when it is returning a value and they are blinking. It looks like it is a master problem, but if I reset the slave board it starts returning the correct value (until it sees another write from the master) So that makes me think it is a slave problem. I stripped almost everything from the slave code so it looks like this
#INT_SSP
void ssp_interupt ()
int i;
BYTE incoming, state;
state = i2c_isr_state();
if(state < 0x80) //Master is sending data
if(state >0)//data not address
if(state == 0x80) //Master is requesting data
donepouring=42;
i2c_write(donepouring);
output_low(PIN_B6);
output_low(PIN_B7);
output_high(PIN_B6);
output_high(PIN_B7);
actionflag=1; //0 = nothing, 1 = read, 2 = change address
//printf("donepouring=%d\r\n",donepouring);
here is the master code. The first read is correct, then there is a write, then the rest of the reads are wrong. Is there something I need to do in the slave int code after a write to reset something?
BoardAddress=0x50;
output_low(PIN_B6);
i2c_start(); // start condition
i2c_write(BoardAddress + 1);
value2 = i2c_read(0);
i2c_stop();
printf(" value before write=%d \r\n",value2);
for(relaynumber=1;relaynumber<=8;relaynumber++)
output_low(PIN_B7);
i2c_start();
i2c_write(BoardAddress); //Address
i2c_write(20); // command for pour
i2c_write(relaynumber); // send relay num
i2c_write(4); // send time to pour
i2c_stop();
Output_high(PIN_B7);
printf("sending command to turn on relay# %d\r\n",relaynumber);
delay_ms(1500);
value2=0;
while(value2!=1) // 0 means still working, 1 means finished
output_low(PIN_B6);
i2c_stop();
printf(" value2=%d \r\n",value2);
_________________ Ringo Davis |
Posted: Sun Jul 22, 2007 2:26 pm |
You didn't have to start a whole new thread on the continuing i2c problem.
Try the master code shown in this post. Use Ex_slave.c for you slave.
See if that works.
http://www.ccsinfo.com/forum/viewtopic.php?t=28097&start=9
Also, vs. 4.007 is too early to use for anything. I would permanently
set that version aside. |
Ringo42
Posted: Sun Jul 22, 2007 4:01 pm |
my slave code is practically identical to ex_slave.
I looked at the post you mentioned and changed my read part to add the additional write and restart before the read like this
value2=0;
output_low(PIN_B6);
i2c_start(); // start condition //new line
i2c_write(BoardAddress); //new line
i2c_stop();
but still get the same result.
The reads work until I do a write, then the reads are bad. any other ideas?
Oh yeah, and I switched to 3.249 and still get the same thing.
Ringo _________________ Ringo Davis |
Posted: Sun Jul 22, 2007 4:49 pm |
Make the master and slave code be identical to the code I posted and
to Ex_Slave.c. Run the slave PIC at 20 MHz. Make sure you have
pull-ups (4.7K) on both SDA and SCL. Compile with 3.249. Make sure
there is a ground connection between the two boards. Don't put in any
other code (outputs to B6, etc). Don't try to run the code in debugger
mode. Run it in stand-alone mode. It should work. |
Ringo42
Posted: Sun Jul 22, 2007 6:25 pm |
I tried the posted example and I get back a B. The only thing my code is doing differently is I'm just writing the address then reading, I'm not writing the address, then a 0, then reading. Is the 0 something I need?
The slave gets it power and ground from the master, both run at 20 mhz, vcc is 5V.
Posted: Sun Jul 22, 2007 9:52 pm |
The Ex_Slave.c code emulates a small EEPROM, so it expects the byte
address to follow the i2c read address. The byte address is used as an
index into a RAM array that emulates the eeprom data. |
Ringo42
Posted: Mon Jul 23, 2007 8:18 am |
I think my I2C code is ok, I think it is something else. I have a bunch of functions in my code below main that do not get called yet. As soon as I deleted all of them it started working correctly.
I've had that happen in one other project where a function stopped about half the I/O pins from working. Deleting and retyping it fixed the problem. I don't know if there is an invisible character or what.
So I'll start pasting stuff back in until it breaks, then see if I can use a different editor to look at that code and see if there is anything weird.
Thanks for the help.
Ringo42
Posted: Sun Jul 29, 2007 1:45 pm |
This is getting weirder. The code posted below allows the I2C stuff to work fine, but my 2 leds on B6 and B7 don't work at all.
If I comment out the
enable_interrupts(INT_RDA) line and the INt_RDA function then the leds work but I2C does not.
If I uncomment the INT_RDA function (whole thing or just the empty brackets) and leave it enabled then Neither I2C or leds work.
Any ideas here on what could be going on? I'm using 3.249.
Ringo
#include <16F876a.h>
#device *=16
#use rs232(baud=19200, xmit=PIN_c6, rcv=PIN_c7)
#include <stdlib.h>
#byte PIC_SSPADD=0x93
int NODE_ADDR = 80; //0x50
//#use i2c(MASTER, SDA=PIN_C4, SCL=PIN_C3, address=0x52)
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x50)
//#define master 1
#define RelayH PIN_A0
#define RelayG PIN_A1
#define RelayF PIN_A2
#define RelayE PIN_B0
#define RelayD PIN_B1
#define RelayC PIN_B2
#define RelayB PIN_B3
#define RelayA PIN_B4
#define Master_Select PIN_C5
#define SERIAL_BUFFER_SIZE 55 //5 + 6*numLiquors
#define numLiquors 8
int SERIAL_BUFFER[SERIAL_BUFFER_SIZE];
#include "Chrfinds.c"
void ProcessCommands();
void Pour();
char FwCmd[] = {"fw"}; // firmware version
char Fw[] = {"1.0.0"};
//char ResetCmd[] = {"reset"}; // reset cpu
//char BlinkCmd[] = {"blink"}; // blinks user leds
char PourCmd[] = {"pour"}; // blinks user leds
//char GainCmd[] = {"setgain"};
int donepouring=0;
int relay[numLiquors];
int time[numLiquors];
int boardnum[numLiquors];
int Sensors=0;
BYTE address, buffer[0x10];
int bytecounter=0;
int actionflag=0; //0 = nothing, 1 = read, 2 = change address
int *curPos; // Current Serial Buffer Ptr Position
int curCnt=0;
int debug=0;
#INT_SSP
int i;
bytecounter++;
/* if(bytecounter>15)// too many bytes, somethign is wrong
bytecounter=0;
printf("i2c overflow\r\n");
return;
incoming = i2c_read();
buffer[bytecounter] = incoming;
if(bytecounter ==3 ) //First received byte is address
if(buffer[1]==20) //pour command
SERIAL_BUFFER[0]='p';
SERIAL_BUFFER[1]=' ';
SERIAL_BUFFER[2]=49; //board address
SERIAL_BUFFER[3]=':';
SERIAL_BUFFER[4]=buffer[2]+48; // relay num
SERIAL_BUFFER[5]=':';
SERIAL_BUFFER[6]=buffer[3]+48; // time
SERIAL_BUFFER[7]='\r';
bytecounter =0;
pour();
if(bytecounter ==8 ) //First received byte is address
for(i=1;i<=8;i++)
printf(" %x ",buffer[i]);
printf("\r\n");
printf("buffer[8]= %d \r\n",buffer[8]);
if((buffer[1]==0) && (buffer[2]==0xa0)
&& (buffer[3]==0) && (buffer[4]==0xaa)
&& (buffer[5]==0) && (buffer[6]==0xa5)
&& (buffer[7]==0))
NODE_ADDR=buffer[8];
PIC_SSPADD=NODE_ADDR;// change address
write_EEPROM (0,NODE_ADDR);// save new address
actionflag=2; //0 = nothing, 1 = read, 2 = change address
bytecounter=0;
// i2c_write(1);
void main ()
int flashcounter=0;
int i;
int data1;
int temp_node_address;
int BoardAddress,relaynumber,value2,x,whileloopcounter;
enable_interrupts(INT_SSP);
enable_interrupts(INT_RDA);
Port_b_pullups(true);
printf("Bartender, firmware v%s\r\n", FW);
// delay_ms(1000);
////////////**************Test code for master*********/////////////////////
while(0)
BoardAddress=0x50;
output_low(PIN_B7);
i2c_start();
i2c_stop();
delay_ms(1500);
whileloopcounter=0;
value2=0;
output_low(PIN_B6);
// i2c_write(BoardAddress);
// i2c_write(0);
// i2c_start(); // start condition
i2c_stop();
printf("%d value2=%d \r\n",whileloopcounter,value2);
whileloopcounter++;
printf("out of while loop\r\n");
}//end of while for test code for master
while (1)
if(actionflag==0) //0 = nothing, 1 = read, 2 = change address
output_high(Pin_b6);
output_high(Pin_b7);
actionflag=0;
if(actionflag==1) //0 = nothing, 1 = read, 2 = change address
output_low(Pin_b6);
output_low(Pin_b7);
delay_ms(125);
delay_ms(125);
actionflag=0;
if(actionflag==2) //0 = nothing, 1 = read, 2 = change address
actionflag=0;
flashcounter=(NODE_ADDR-80);
flashcounter/=2;
flashcounter++;
for(i=0;i<flashcounter;i++)
delay_ms(250);
Output_Low(PIN_B6);
Output_Low(PIN_B7);
delay_ms(250);
void Pour()
int i=0;
int j=0;
signed int sPos, ePos;
int quarterseconds=0;
int BoardAddress=0;
int value;
sPos = 0;
donepouring=0;
// Find end of command, and set to null:
ePos = chrFind('\r', SERIAL_BUFFER, 0);
SERIAL_BUFFER[ePos] = '\0';
// Go find first space:
sPos = chrFind(' ', SERIAL_BUFFER, 0);
while (sPos != -1)
boardnum[i]=getNextNumBeforeColon(&sPos);//after the space
relay[i] = getNextNumBeforeColon(&sPos);//after the colon
time[i] = getNextNumBeforeSpace(&sPos);
i++;
sPos = chrFind(' ', SERIAL_BUFFER, sPos);
for(j=0;j<i;j++)
printf("pouring relay# %d for %d time\r\n",relay[j],time[j]);
if(boardnum[j]==1) //this board
switch (relay[j])
case 1: output_high(RelayA); break;
case 2: output_high(RelayB); break;
case 3: output_high(RelayC); break;
case 4: output_high(RelayD); break;
case 5: output_high(RelayE); break;
case 6: output_high(RelayF); break;
case 7: output_high(RelayG); break;
case 8: output_high(RelayH); break;
for(quarterseconds=0;quarterseconds<time[j];quarterseconds++)
delay_ms(250);
output_low(RelayA);
output_low(RelayB);
output_low(RelayC);
output_low(RelayD);
output_low(RelayE);
output_low(RelayF);
output_low(RelayG);
output_low(RelayH);
printf("done pouring\r\n");
donepouring=1;
return;
else // Slave Board, send out command
printf("Sending I2c command to board %d\r\n",boardnum[j]);
// send command via I2C
BoardAddress=boardnum+0x40;
i2c_start();
delay_ms(15);
delay_ms(15);
i2c_write(relay[j]); // send relay num
delay_ms(15);
i2c_write(time[j]); // send time to pour
delay_ms(15);
i2c_stop();
delay_ms(500); // give the board time to pour
value=0;
while(value==0) // 0 means still working, 1 means finished
printf("asking slave board if it is finished\r\n");
value = i2c_read(0);
i2c_stop();
delay_ms(200); // give the board time to pour
/* removing this line makes #int_rda an empty function, but it kills I2C comms
#int_rda
void serial_int_routine()
disable_interrupts(INT_RDA); // RS232 OFF
// Read incoming byte:
*curPos = getc();
// Make sure we don't overrun the buffer:
if (curCnt < SERIAL_BUFFER_SIZE)
// End of command, set flag to process the command:
if (*curPos =='\r')
// ProcessCommands();
// Reset pointer to beginning of buffer:
curPos = SERIAL_BUFFER;
curCnt = 0;
// Increment buffer position:
curPos++;
curCnt++;
curCnt = 0;
enable_interrupts(INT_RDA); // RS232 ON
int brightest=0;
printf("\r\nentering Process commands\r");
// printf("\n spos=%d\r\n",sPos);
if(strncmp ( PourCmd, serial_buffer, 3)==0)
printf("Pouring\r\n");
pour();
printf("NACK\r\n");
Ringo42
Posted: Sun Jul 29, 2007 2:42 pm |
I don't have to comment out the entire serial interupt, jus the line
//#INT_RDA
which makes it an interupt.
the function is still there.
with
//#INT_RDA
I get no leds, but I2C works perfectly
with
#INT_RDA
The leds work fine but I2C works 2 to 4 times (random) then always returns a -1, even when it is hard coded to reurn a 1 like this i2c_write(1);
Any ideas?
Ringo42
Posted: Thu Aug 02, 2007 10:36 pm |
It looks like I can't have both of these at the same time
#use I2C(master, sda=PIN_c4, scl=PIN_c3)
I can get serial to work, or I2C, but as soon as I include both statements the interrupts quit. Has anybody seen this before. I'm using a 16f876A.
Thanks,
Posted: Fri Aug 03, 2007 7:03 am |
In what you have posted, you are enabling a RS232 interrupt, but show no handler. This will cause everything to hang, if data is seen on the serial line....
Ringo42
Posted: Fri Aug 03, 2007 7:43 am |
What I posted before was slave code. I took out all the serial stuff and now I2C works. But now I'm working on master code which needs both Serial and I2C. I've been stripping stuff out to try to get it working. Here is the current version. As soon as I put in the Use I2C line the serial int quits working.
#device *=16
#include <stdlib.h>
void Pour();
int timearray[numLiquors];
int relaynum=0;
int time=0;
int donepouring=1;
BYTE address;
BYTE buffer[20];
int curCnt=0;
int debug=0;
void main ()
int x;
printf("\rBartender Master board\r\n");
for(x=0;x<5;x++)
output_low(PIN_B7);
output_low(PIN_B6);
// while (0)
time=1;
for(relaynum=1;relaynum<=8;relaynum++)
pour();
// while(0)
// int BoardAddress=0x50;
// int relaynumber;
// int whileloopcounter;
// int value2;
// for(relaynumber=1;relaynumber<=8;relaynumber++)
// output_low(PIN_B7);
// i2c_start();
// i2c_write(BoardAddress); //Address
// i2c_write(20); // command for pour
// i2c_write(relaynumber); // send relay num
// i2c_write(4); // send time to pour
// i2c_stop();
// Output_high(PIN_B7);
// printf("sending command to turn on relay# %d\r\n",relaynumber);
// delay_ms(1500);
// whileloopcounter=0;
// value2=0;
// while(value2!=1) // 0 means still working, 1 means finished
// output_low(PIN_B6);
// delay_ms(500);
// i2c_write(BoardAddress + 1);
// value2 = i2c_read(0);
// i2c_stop();
// output_high(PIN_B6);
// printf("%d value2=%d \r\n",whileloopcounter,value2);
// whileloopcounter++;
// printf("out of while loop\r\n");
// }//end of while for test code for master
while (1)
output_low(Pin_b6);
output_low(Pin_b7);
delay_ms(125);
delay_ms(125);
actionflag=0;
if(actionflag==3) //0 = nothing, 1 = read, 2 = change address
output_low(Pin_b6);
delay_ms(125);
output_low(Pin_b6);
delay_ms(125);
pour();
actionflag=0;
void Pour()
int x;
//time=4;
//relaynum=3;
printf("\r\npouring relay# %d for %d time\r\n",relaynum,time);
switch (relaynum)
output_high(PIN_b6);
output_high(PIN_b7);
//delay_ms(1000);
for(x=0;x<time;x++)
delay_ms(250);
output_low(PIN_b6);
output_low(PIN_b7);
output_low(RelayA);
output_low(RelayB);
output_low(RelayC);
output_low(RelayD);
output_low(RelayE);
output_low(RelayF);
output_low(RelayG);
output_low(RelayH);
// printf("done pouring\r\n");
donepouring=1;
// return;
int i=0;
printf("\r\nprocess commands\r\n");
sPos = 0;
while (sPos != -1)
relaynum = getNextNumBeforeColon(&sPos);//after the colon
time = getNextNumBeforeSpace(&sPos);
i++;
pour();
#int_rda //HIGH
// disable_interrupts(INT_RDA); // RS232 OFF
output_high(PIN_b6);// these 3 lines only put in for troubleshooting. Delay would not be in real code
output_low(PIN_b6);
*curPos = getc();
if (*curPos =='\r')
ProcessCommands();
curCnt = 0;
output_low(PIN_b6);
curPos++;
curCnt++;
curCnt = 0;
Any help will be greatly appreciated.
Thanks, Ringo _________________ Ringo Davis |
Ringo42
Posted: Fri Aug 03, 2007 8:34 am |
Here is an even more stripped down version that still does not work. The int_rda function is copied straight from a working program, so I know the code is good. Every once in a while the program will work, but changing something as simple as adding a character in a printf will make it not work. | Code: |
#device *=16
//#use I2C(master, sda=PIN_c4, scl=PIN_c3)
#use rs232(baud=19200, xmit=PIN_c6, rcv=PIN_c7,ERRORS)
#define SERIAL_BUFFER_SIZE 25 //55 //5 + 6*numLiquors
void processCommands();
int curCnt=0;
void main ()
int x;
printf("\r\nBartender Master board\r\n");
for(x=0;x<5;x++)
output_low(PIN_B7);
output_low(PIN_B6);
while (1)
#int_rda
output_low(PIN_b6);
*curPos = getc();
if (*curPos =='\r')
curCnt = 0;
output_low(PIN_b6);
ProcessCommands();
curPos++;
curCnt++;
curCnt = 0;
printf("process commands\r\n");
Posted: Fri Aug 03, 2007 4:00 pm |
| Quote: |
void main ()
int x;
for(x=0;x<5;x++)
output_low(PIN_B7);
output_low(PIN_B6);
while (1)
#int_rda
output_low(PIN_b6);
*curPos = getc(); |
It can't work because 'curpos' is never initialized to point to an array.
On the first character, it will start over-writing RAM, probably at address
0x00, which is the start of the SFR registers in the PIC.
I would get rid of your #int_rda code and just use the code in Ex_sisr.c.
Don't do any processing inside the RDA isr. Do it all in main(). In other
words, keep everything ultra-simple. |
