		| Author | Message |
		| Jester Guest
				| Problems after implementing the microchipc bootloader |
				|  Posted: Thu Nov 06, 2003 7:46 am |   |
				| Hi
 I'm working with 16F877. My program has been ok, but now i implemented the bootloader from www.microchipc.com (the 20MHz version of hex files) i have faced some problems.
 The bootloader is working fine, and also most of my own code is working as it does when i program my chip with PicStart Plus- programmer.
 Anyhow one very important part of my code doesn't work after i have used the Microchipc bootloader. The program simply just hangs. So i quess that some part of my code points somewhere in memory that it shouldn't point. When programming the chip with PicStart this failure dissapears. Has anyone had similar problems?
 -J
 My compiler version is 3.178
		| PCM programmer
				|  Posted: Thu Nov 06, 2003 11:19 am |   |
				| Here are two possible reasons:
 1.   Since the bootloader runs in the top 256 bytes of ROM, you need
 to reserve that space and prevent the compiler from using it.
 Do it with the #org statement, like this:
 #org 0x1F00, 0x1FFF {}
 main()
 2.  The hex file from Microchipc comes with the LVP fuse enabled.
 So, suppose you have a line of code in your program that turns
 on the Port B pull-ups.   The program will instantly lock up,
 because taking pin B3 high will put the PIC into Low Voltage
 programming mode.
 Solution:
 Import the hex file into MPLAB again.  Bring up the Picstart-Plus
 programming window.   Change the config bit setting for LVP
 to Disabled.   Now re-program the 16F877.
 If you do these two things, it will probably fix your problems.
		| Jester Guest
				|  Posted: Fri Nov 07, 2003 12:22 am |   |
				| Clearing the LVP bit did the magic!!!
 PCM Programmer have you ever thought that your advices are worth of money! If so, you are doing great charity work
 All the Best!
 -J
		| nicksiz Guest
				| bootloader |
				|  Posted: Mon Jul 09, 2007 2:16 am |   |
				| I tryıng about bootloader but a problem here;
 ı am using microchip firm ware for 16f877a
 and my main program is that;
 #include <16F877A.h>
 #device adc=8
 #FUSES NOWDT                    //No Watch Dog Timer
 #FUSES HS                       //High speed Osc (> 4mhz)
 #FUSES NOPUT                    //No Power Up Timer
 #FUSES NOPROTECT                //Code not protected from reading
 #FUSES NODEBUG                  //No Debug mode for ICD
 #FUSES NOBROWNOUT               //No brownout reset
 #FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
 #FUSES NOCPD                    //No EE protection
 #FUSES NOWRT                    //Program memory not write protected
 #use delay(clock=18432000)
 #org 0x1f00,0x1fff
 //write_eeprom(0,0x00FF);
 if(!input(pin_b0)){goto_address(0x0000);}
 output_high(pin_b1);
 output_low(pin_b1);
 output_high(pin_b2);
 output_low(pin_b2);
 output_high(pin_b3);
 output_low(pin_b3);
 ı am programıng pic with firmware than with picdem 2 plus ı am tryıng bootloading the microchip pic16f/18f bootloader gives that error.mcp
 000030 00 34 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 004000 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 3A 3F
 what can ı do
 | You cannot post new topics in this forum You cannot reply to topics in this forum
