cfernandez
PORTB Problem |
Posted: Wed Jul 04, 2007 7:55 pm |
I use a 18F4620 25Mhz, and I need use the PortB.0 to PortB.4 for digital input. In this pins I connect a Magnetic Card Reader, in the pin 0 connect the card present, this is high when not is a card, and low when exist a card. The problem is that the pin 0 and 1 not is possible to get the 0 or 1 value from the mag. card reader, the other pins work fine. If I put the pin 0 or 1 to ground I see that signal change from 1 to 0.
Why cannot work the pin 0 and 1 from port b for detect digital input??. Any can help me.
This is my test code
Code: | #include <18F4620.h>
#fuses HS,NOLVP,NOWDT,NOPROTECT
#use delay(clock=25000000)
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7)
#use fast_io( B )
int index;
int error;
port_b_pullups( FALSE );
set_tris_b( 0xFF );
error = 0x00;
while( 1 )
index = input_b( );
if ( index != error )
printf( "%u%u%u%u%u%u%u%u\n\r", bit_test( index, 7 ), bit_test( index, 6 ), bit_test( index, 5 ), bit_test( index, 4 ), bit_test( index, 3 ), bit_test( index, 2 ), bit_test( index, 1 ), bit_test( index, 0 ) );
error = index;
Thank you very much!! |
Posted: Wed Jul 04, 2007 10:33 pm |
It may need a pull-up resistor. Post a link to the data sheet of the
card reader. |
cfernandez
Posted: Thu Jul 05, 2007 1:23 pm |
I am use a Kit from CCS and in this kit connect my reader, the problem is that this kit have a connector for GPIO, but the PIN 0 and 1 from PORT B is use for the Ethernet Chip and I have not the schematic for see this information. CCS send me a email with this.
Thank you very much PCM for your time.
Best Regards, |
