orlandoG
| Read Pulse w ADC |
Posted: Thu Jun 28, 2007 4:56 pm |
Hello!
Can someone help me? Here is what I am doing. I have 4 NPN transistors (base) connected to PORTB 0-3 (a basic emmiter follower) . I am pulsing each transistor in a state machine and reading back the (load) voltage with the built in ADC and graphing the data on a GUI program.
Here is the problem! I am not getting back ALL the pulses I send out. (Missing data) I should see all the pulses at the load voltage level. I'm thinking the ADC is not fast enough or its doing its routine before the ADC can read it
Does anyone have a better way to do this? If someone can figure this out can you post example code. I have posted the working code below
Thanks In Advance!
#include <16F873.h>
#device adc=10
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
/******************** Local Variable Declarations *****************************/
int Selected=0;
enum Port {B0=PIN_B0,B1=PIN_B1,B2=PIN_B2,B3=PIN_B3};
/******************** Initialize Ports *****************************************/
void Initialize(void)
setup_adc_ports(ALL_ANALOG);
/******************** Send Out A Pulse *****************************************/
void Pulse(int port,int delay)
output_low(port);
delay_ms(delay);
output_high(port);
delay_ms(delay);
/******************** Read Analog To Digital Converter *************************/
void ADC(int channel)
long Raw_Value;
set_adc_channel(channel);
delay_ms(10);
Raw_Value = read_adc();
printf("CH%d,%Lu \r",channel, Raw_Value);
/******************** Pulse and Read Voltage From Each Load *************************/
void AnalyseLoad(void)
switch(Selected)
case 0:
ADC(0); //Read Supply Voltage
Selected=1;
case 1:
Pulse(B0,1); //Pulse Load 1
ADC(1); // Read Voltage
Selected=2;
case 2:
Pulse(B1,1); //Pulse Load 2
ADC(2); //Read Voltage
Selected=3;
case 3:
Pulse(B2,1); //Pulse Load 3
ADC(3); //Read Voltage
Selected=4;
case 4:
Pulse(B3,1);} //Pulse Load 4
ADC(4); //Read Voltage
Selected=0;
/******************** Main Loop ************************************************/
Initialize();
while (TRUE)
AnalyseLoad();
Posted: Thu Jun 28, 2007 5:17 pm |
| Quote: | | I'm thinking the ADC is not fast enough or its doing its routine before the ADC can read it |
I didn't try to understand your program, but you're concerned about
the ADC conversion speed, and you have a 10 ms delay after setting
the channel. This really only needs to be 20 us (not ms) or less.
You can change it to: delay_us(20);
| Quote: | void ADC(int channel)
long Raw_Value;
delay_ms(10); // Really only need a 20 us delay
Also, your printf statement will take about 1/4 ms per character. |
