| Long serial timeout |
Posted: Fri Jun 22, 2007 3:37 am |
Have done many searches but couldn't find answer I was looking for.
PIC is 16LF877 4Mhz. Compiler. 3.181
I am using the code below to read in a serial string.
This works fine.
What I want to to be able to time out if nothing is received for about 10 seconds.
All other timeout routines seem to be too short.
Thanks in advance
Steve
| Code: | #include "C:\PIC_C_Code\Smart Modem\Smart Modem.h"
#include <string.h>
void Get_String2();
void get_string(char* s, int max);
#define MAX_BUFFER 10
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
//Get_Char();
Get_String2();
return;
void Get_String2()
char string[MAX_BUFFER];
printf("please type a string: ");
// Wait for a key press
while(!kbhit(MODEM));
get_string(string, MAX_BUFFER);
fprintf(RDTG,"%s",string);
int len;
char c;
--max;
len=0;
do {
c=fgetc(MODEM);
// if(c==8) { // Backspace
// if(len>0) {
// len--;
// putc(c);
// putc(' ');
// putc(c);
// } else
if ((c>=' ')&&(c<='~'))
if(len<max) {
s[len++]=c;
putc(c);
} while(c!=13);
s[len]=0;
Humberto
Posted: Sat Jun 23, 2007 9:56 pm |
V3.181 is quite old, I´m not sure if in the Examples folder you have the EX_TGETC.C
program that shows exactly what you need.
Humberto |
Posted: Thu Jun 28, 2007 2:28 am |
Many Thanks Humberto.
I do have that piece of code.
Was reluctant to use it as I didn't think it would be possible to achieve the 10 seconds I would like?
Is it possible?
(I will play in the meantime)
Thanks again
Steve |
Humberto
Posted: Thu Jun 28, 2007 6:56 am |
Steve,
With the pointed example, I wish you get the way, how to do it. The program
was used widely and I´m not aware of something wrong using it. Of course you
will need to adapt it to your 10 sec timeout application.
Humberto |
kevcon
Joined: 21 Feb 2007 Posts: 142 Location: Michigan, USA
Posted: Thu Jun 28, 2007 7:29 am |
Setup a timer to interrupt every 1ms and count to 10000
voidt main( void )
unsigned int16 timeOutCounter = 0;
set_rtcc( SomeValue );
while( !kbhit( MODEM ) && ( timeOutCounter < 10000 ) );
if ( timeOut Counter > 10000 ) }
timeOutCounter = 0;
///timout code goes here
else {
//kbhit code goes here
#pragma INT_RTCC
void ms_timer( void )
timeOutCounter++
Posted: Thu Jun 28, 2007 8:36 am |
Getting there. Thanks to all.
Just adapting the example code to suit works fine. |
newbie_1974
| timeout |
Posted: Thu Jul 05, 2007 12:05 am |
| hi, would it be possible to get a copy of your time out code, thanks. |
