version 3.2x and pic18f1220
roby
PostPosted: Tue Jun 19, 2007 1:11 pm     Reply with quote
I have a problem with pic18f1220. Using the same program if I compile for 18f4520 it works if I compile for 18f1220 it does not work!
Thank You
PostPosted: Tue Jun 19, 2007 2:36 pm     Reply with quote
If you switch to a new PIC and it doesn't work, it's possibly a hardware
problem. Try a simple program to blink an LED. See if it works:
http://www.ccsinfo.com/forum/viewtopic.php?t=30916&highlight=18f1220&start=9
Also, if you're using an external crystal, then change the #fuses and
#use delay() statements to match your crystal frequency.
PostPosted: Wed Jun 20, 2007 2:29 am     Reply with quote
I have already do what You say.
The problem still exitsts.
After I tried Mplab and I see that the debugger stops random.
My program is not simply, can I send it to You?
