nina
| flex_lcd |
Posted: Fri Jun 15, 2007 1:02 pm |
I am trying use driver flex_lcd.c but do not work up to now.
my code is
#include <16f877.h>
#fuses nowdt,noput,nobrownout,nolvp,noprotect
#define use_portb_lcd 1
#include <flex_lcd.c>
#use standard_io (B)
lcd_init(); //Inicia LCD
set_tris_b(0x00); /*PortB saida*/
lcd_putc("Teste"); //Escreve texto
The design is:
http://pg.photos.yahoo.com/ph/fernandoazevedo.rm/detail?.dir=5108re2&.dnm=546cre2.jpg&.src=ph
when I try compile appear the follow message:
undefined identifier LCD_DB4
Does anyone here can help me pls?
thanks |
Posted: Fri Jun 15, 2007 1:31 pm |
| Quote: | When I try compile appear the follow message:
undefined identifier LCD_DB4 |
Look at the driver code. It has the #define statements for the pins at
the start of the file. You must have those lines there. Don't delete them.
Based on your drawing, here are the #define statements for your board:
#define LCD_DB4 PIN_B1
#define LCD_DB5 PIN_B2
#define LCD_DB6 PIN_B3
#define LCD_DB7 PIN_B4
#define LCD_E PIN_B5
#define LCD_RS PIN_B7
#define LCD_RW PIN_B6
#define USE_LCD_RW 1
| Quote: |
The "use_portb_lcd" line is not used with the Flex LCD driver. It's for the CCS LCD driver. Delete it.
Also, in your drawing, you have connected the LCD contrast pin (pin 3)
to +5v. That's wrong. It should be between 0v and 0.5v. Probably
a voltage of 0.4v will give the best contrast. Use a trimpot or a two
resistors (arranged as a voltage divider) to set the contrast voltage.
Finally, you are missing the oscillator fuse setting. You need to add
XT to the fuses as shown in bold below:
| Quote: |
#include <16f877.h>
#fuses XT,nowdt,noput,nobrownout,nolvp,noprotect
There's another error. In your drawing, capacitor C2 is 1 nF.
That's wrong. It should be 22 pf, just like capacitor C1.
Change it.
Also, you have connected pin RA5 to ground. Why ?
Remove that connection. |
nina
| perfect |
Posted: Fri Jun 15, 2007 2:06 pm |
many thanks pcm programmer...
It is working now.
I saw also if I took the line
set_tris_b(0x00);
also work without problem
thanks again |
