Comunication pic to pic with two 16f628 chips
aletavola
PostPosted: Mon Jun 11, 2007 2:45 pm     Reply with quote
Hi friends;
I have two 16f628, one need to talk to PC by rs232, do delta sigma AD and send a messages the other 16f628.
I2C is a good idea? How can i implement i2c slave mode in 16f628?
Alexandre Tavola
PostPosted: Mon Jun 11, 2007 3:02 pm     Reply with quote
The 16F628 doesn't have an SSP module, so there's no easy way to
do an i2c slave.
aletavola
PostPosted: Mon Jun 11, 2007 3:07 pm     Reply with quote
Any sugestion? I just need to send a message to another pic.
aletavola
PostPosted: Mon Jun 11, 2007 3:13 pm     Reply with quote
Can i use another two pins of first chip to send serial data to the second pin?
i have two pins available.
arunb
RE:
PostPosted: Mon Jun 11, 2007 3:56 pm     Reply with quote
Yes you can use serial method, but you may need to use interrupts on the receive pins, for better efficiency.
thanks
arunb
aletavola
PostPosted: Mon Jun 11, 2007 5:02 pm     Reply with quote
i have no ideia how to implement this... but... i think is is not so difficult.
i belive that i can use two streams, one for pc and other for pic intercom.
i just need to write a value to second pic.
I belive that i just need to implement a software uart in first pic and write data to it. (the second pic is watting the info with gets()) and use the hard uart to comm with pc.
Alexandre
dyeatman
PostPosted: Tue Jun 12, 2007 7:03 am     Reply with quote
Just FYI, There is a simple PIC-to-PIC comm setup in the CCS FAQ:
http://www.ccsinfo.com/faq.php?page=connect_pics
