hanhao
| PIC16F687: problem with kbhit and getc |
Posted: Wed May 23, 2007 6:34 pm |
hi,i got a problem with kbhit and getc, here is my code
#use rs232(baud=9600,parity=N,xmit=PIN_B7,rcv=PIN_B5,stream=GPS)
in main....
if(kbhit(GPS))
temp_char = getc(GPS);
printf("temp_char = %c", temp_char);
what happens is that kbhit never detects any RS232 data even though there is data sent from my com port. No printf message comes up. i confirmed this with my O scope. is there something wrong with this algorithm?
i am using PIC16F687 |
Posted: Wed May 23, 2007 7:16 pm |
Post your compiler version. You can find it at the top of the .LST file.
Look for that file in your project directory. It's a 4-digit number like
3.249, 4.013, 4.038, etc. |
hanhao
Posted: Wed May 23, 2007 7:51 pm |
| PCM programmer wrote: | Post your compiler version. You can find it at the top of the .LST file.
4.013 |
Posted: Wed May 23, 2007 9:54 pm |
I don't have that version. The closest I have is vs. 4.014.
Can you compile the following program, and post the first part of
the .LST file ?
I need to see the LST file code that comes just after the start of main().
#include <16F687.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT
int8 temp_char;
if(kbhit(GPS))
Here's the part of the .LST file that starts with main(). This code is
for vs. 4.038. Post the LST file code that you get after compiling
with vs. 4.013. This will show how the PIC's registers are setup.
I think there may be a problem with the setup of the UART registers
in your version.
0017: CLRF 04
0018: MOVLW 1F
0019: ANDWF 03,F
001A: BSF 03.5
001B: BCF 1B.3
001C: MOVLW 19
001D: MOVWF 19
001E: MOVLW A6
001F: MOVWF 18
0020: MOVLW 90
0021: BCF 03.5
0022: MOVWF 18
0023: BSF 03.6
0024: BCF 1F.0
0025: BCF 1F.1
0026: BCF 1F.2
0027: BCF 1F.3
0028: BCF 03.6
0029: BCF 1F.6
002A: MOVLW 00
002B: BSF 03.6
002C: MOVWF 1E
002D: CLRF 19
002E: CLRF 1A
002F: BSF 03.5
0030: CLRF 1E
0031: BCF 03.5
0032: CLRF 1B
0033: BCF 03.6
0034: BCF 0D.5 |
hanhao
Posted: Thu May 24, 2007 1:42 am |
sry i am not good in assembly
hope you can find something from here
| Code: | void main()
0017: CLRF 04
0018: BCF 03.7
0019: MOVLW 1F
001A: ANDWF 03,F
001B: BSF 03.5
001C: BCF 1B.3
001D: MOVLW 0C
001E: MOVWF 19
001F: MOVLW A2
0020: MOVWF 18
0021: MOVLW 90
0022: BCF 03.5
0023: MOVWF 18
0024: BSF 03.6
0025: BCF 1F.0
0026: BCF 1F.1
0027: BCF 1F.2
0028: BCF 1F.3
0029: BCF 03.6
002A: BCF 1F.6
002B: MOVLW 00
002C: BSF 03.6
002D: MOVWF 1E
002E: MOVLW 07
002F: MOVWF 19
0030: MOVLW FF
0031: MOVWF 1A
0032: BSF 03.5
0033: CLRF 1E
0034: BCF 03.5
0035: CLRF 1B
0036: BCF 03.6
0037: BCF 0D.5
.................... setup_adc_ports(PIN_17_ADC|VSS_VDD);
003D: BSF 03.6
003E: BCF 1F.0
003F: BCF 1F.1
0040: BCF 1F.2
0041: BCF 1F.3
0042: BCF 03.6
0043: BCF 1F.6
0044: MOVLW 00
0045: IORLW 02
0046: BSF 03.6
0047: MOVWF 1E
.................... setup_adc(ADC_CLOCK_INTERNAL);
0048: BSF 03.5
0049: BCF 03.6
004A: BSF 1F.4
004B: BSF 1F.5
004C: BCF 1F.6
004D: BCF 03.5
004E: BSF 1F.7
004F: BSF 1F.0
.................... setup_spi(FALSE);
0050: BCF 14.5
0051: BSF 03.5
0052: BCF 07.7
0053: BSF 06.4
0054: BCF 06.6
0055: MOVLW 00
0056: BCF 03.5
0057: MOVWF 14
0058: BSF 03.5
0059: MOVWF 14
.................... // setup_timer_0(RTCC_EXT_L_TO_H|RTCC_DIV_1);
.................... // setup_timer_1(T1_DISABLED);
.................... //setup_oscillator(False);
.................... setup_oscillator(OSC_8MHZ);
005A: MOVLW 71
005B: MOVWF 0F
.................... output_float(PIN_17_PIN);
005C: BSF 05.2
.................... while(1)
.................... while ( !input(PIN_C5) )
005D: BSF 07.5
005E: BCF 03.5
005F: BTFSC 07.5
0060: GOTO 07B
.................... if(kbhit(GPS))
0061: BTFSS 0C.5
0062: GOTO 078
.................... temp_char = getc(GPS);
0063: BTFSS 0C.5
0064: GOTO 063
0065: MOVF 1A,W
0066: MOVWF 2D
.................... printf("temp_char = %c", temp_char);
0067: CLRF 2E
0068: MOVF 2E,W
0069: CALL 004
006A: INCF 2E,F
006B: MOVWF 20
006C: MOVF 20,W
006D: BTFSS 0C.4
006E: GOTO 06D
006F: MOVWF 19
0070: MOVLW 0C
0071: SUBWF 2E,W
0072: BTFSS 03.2
0073: GOTO 068
0074: MOVF 2D,W
0075: BTFSS 0C.4
0076: GOTO 075
0077: MOVWF 19
.................... // main_sequence();
0078: BSF 03.5
0079: GOTO 05D
007A: BCF 03.5
007B: BSF 03.5
007C: GOTO 05D |
Posted: Thu May 24, 2007 1:46 am |
| Please compile the program that I posted. |
hanhao
Posted: Thu May 24, 2007 9:55 pm |
| PCM programmer wrote: | | Please compile the program that I posted. |
CCS PCM C Compiler, Version 4.013, 28193 25-May-07 11:47
Filename: kbit.lst
ROM used: 81 words (4%)
Largest free fragment is 1967
RAM used: 8 (6%) at main() level
8 (6%) worst case
Stack: 1 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 017
0003: NOP
.................... #include <16F687.h>
.................... //////// Standard Header file for the PIC16F687 device ////////////////
.................... #device PIC16F687
.................... #list
.................... #fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT
.................... #use delay(clock=4000000)
.................... #use rs232(baud=9600,parity=N,xmit=PIN_B7,rcv=PIN_B5,stream=GPS)
0017: CLRF 04
0018: BCF 03.7
0019: MOVLW 1F
001A: ANDWF 03,F
001B: BSF 03.5
001C: BCF 1B.3
001D: MOVLW 19
001E: MOVWF 19
001F: MOVLW A6
0020: MOVWF 18
0021: MOVLW 90
0022: BCF 03.5
0023: MOVWF 18
0024: BSF 03.6
0025: BCF 1F.0
0026: BCF 1F.1
0027: BCF 1F.2
0028: BCF 1F.3
0029: BCF 03.6
002A: BCF 1F.6
002B: MOVLW 00
002C: BSF 03.6
002D: MOVWF 1E
002E: MOVLW 07
002F: MOVWF 19
0030: MOVLW FF
0031: MOVWF 1A
0032: BSF 03.5
0033: CLRF 1E
0034: BCF 03.5
0035: CLRF 1B
0036: BCF 03.6
0037: BCF 0D.5
.................... int8 temp_char;
0038: BTFSS 0C.5
0039: GOTO 04F
003A: BTFSS 0C.5
003B: GOTO 03A
003C: MOVF 1A,W
003D: MOVWF 26
003E: CLRF 27
003F: MOVF 27,W
0040: CALL 004
0041: INCF 27,F
0042: MOVWF 20
0043: MOVF 20,W
0044: BTFSS 0C.4
0045: GOTO 044
0046: MOVWF 19
0047: MOVLW 0C
0048: SUBWF 27,W
0049: BTFSS 03.2
004A: GOTO 03F
004B: MOVF 26,W
004C: BTFSS 0C.4
004D: GOTO 04C
004E: MOVWF 19
004F: GOTO 038
0050: SLEEP
Configuration Fuses:
Word 1: 3FE1 XT NOPROTECT BROWNOUT MCLR NOCPD NOWDT PUT IESO FCMEN |
Posted: Thu May 24, 2007 11:14 pm |
I looked at the startup code for your version, and added the comments
shown below. There are two bugs in it, regarding the setup of the
comparator registers. You can fix the bugs by adding the lines shown in
bold below. (In vs. 4.038, they have fixed these bugs).
| Quote: |
#include <16F687.h>
#byte CM1CON0 = 0x119
#byte CM2CON0 = 0x11A
int8 temp_char;
CM1CON0 = 0x00;
CM2CON0 = 0x00;
if(kbhit(GPS))
Here's the .LST file with comments added.
0017: CLRF 04
0018: BCF 03.7
0019: MOVLW 1F
001A: ANDWF 03,F
001B: BSF 03.5
001C: BCF 1B.3 // BRG16 = 0
001D: MOVLW 19
001E: MOVWF 19 // SPBRG = 0x19
001F: MOVLW A6
0020: MOVWF 18 // TXSTA = 0xA6
0021: MOVLW 90
0022: BCF 03.5
0023: MOVWF 18 // RCSTA = 0x90
0024: BSF 03.6
0025: BCF 1F.0 // ANSELH = 0 (all digital i/o)
0026: BCF 1F.1
0027: BCF 1F.2
0028: BCF 1F.3
0029: BCF 03.6
002A: BCF 1F.6 // VCFG = 0
002B: MOVLW 00
002C: BSF 03.6
002D: MOVWF 1E // ANSEL = 0x00 (all digital i/o)
002E: MOVLW 07
002F: MOVWF 19 // CM1CON0 = 0x07 -- BUG: should be 0x00
0030: MOVLW FF
0031: MOVWF 1A // CM2CON1 = 0xFF -- BUG: should be 0x00
0032: BSF 03.5
0033: CLRF 1E // SRCON = 0x00
0034: BCF 03.5
0035: CLRF 1B // CM2CON1 = 0x00
0036: BCF 03.6
0037: BCF 0D.5 // C1IF = 0
hanhao
Posted: Mon May 28, 2007 2:22 am |
hi
thanks for your solution
but unfortunately it does not work
kbhit(GPS) never returns true and its sampling rate is higher than rs232 baud rate
a work around used is
| Code: | if(!input(PIN_B6))
but unfortunately it's a "cheater" method that i wont want to use
another mistake i made earlier on is[b]
i changed to
#use rs232(baud=9600,parity=N,xmit=PIN_B7,rcv=PIN_B6,stream=GPS) |
Posted: Mon May 28, 2007 2:49 am |
It wasn't really a solution. It was just one thing that I noticed was wrong
with the generated code.
If you use pin B6 as the 'rcv' pin with the 16F687, the compiler will
generate code for a software UART. The 'xmit' side will also be created
as a software UART.
You should change your hardware connections so the serial port uses
the hardware UART pins (B7 and B5 on the 16F687) and also add the
ERRORS parameter. Example:
#use rs232(baud=9600,xmit=PIN_B7,rcv=PIN_B5,stream=GPS, ERRORS) |
hanhao
Posted: Tue May 29, 2007 2:14 am |
yes that solved the problem
i shorted the pin to pin 12 instead of 11
no bug fixing was done
thanks |
Douglas Kennedy
Posted: Tue May 29, 2007 2:49 am |
The above prints 13 chars for every char received from the GPS. It may be good enough for testing but it requires that the GPS data stream be idle
(1-1/13)%=92% of the time for reliable receipt of GPS data. |
