tesla80
| 18f252 rs232 int_rda problem |
Posted: Wed May 23, 2007 1:37 pm |
Hi all,
I've connected 18F252 with max232 to PC, when the first power came; 3 unlikely interrupts show up, and then when i try to send something from hyperterminal (or terminal or Docklight) ,there is no interrupt so it doesn't take any data, it sends data but it doesn't take back.
i did the similar work before with 16 series Pics and they work good.What kind of differences can be on F252, What am i suppose to do about it ?
Code is here:
| Code: | #include <18F252.h>
#device *=16 adc=10
#FUSES NOWDT,HS,NOPROTECT,NOOSCSEN,BROWNOUT,NOPUT,STVREN
,NODEBUG,NOLVP,NOWRT,NOWRTD,NOWRTB,NOWRTC,NOCPD,NOCPB,
NOEBTR,NOEBTRB
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#priority RDA
#byte PORTC = 0xF82
#byte PORTB = 0xF81
#byte PORTA = 0xF80
#bit BusyLED = PORTB.4
#int_RDA
void RDA_isr() {
putc(getc());
printf("int_RDA\n");
//setup_adc_ports(AN0_VREF_VREF);
//setup_adc(ADC_CLOCK_DIV_64);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
SETUP_TIMER_0(RTCC_INTERNAL|RTCC_DIV_1);
SETUP_TIMER_1(T1_DISABLED); // Disable Timer 1
SETUP_TIMER_2(T2_DISABLED, 127, 1); // Disable Timer 2
SETUP_TIMER_3(T3_DISABLED); // Disable Timer 3
SETUP_CCP1(CCP_OFF); // Disable CCP1
SETUP_CCP2(CCP_OFF); // Disable CCP2
SET_TRIS_A(0b00001111);
SET_TRIS_B(0b00000100);
SET_TRIS_C(0);
PORTA = 0;
PORTB = 0;
PORTC = 0;
BusyLED=1;
enable_interrupts(INT_RDA);
delay_ms(200);
printf("Start\n");
for(;;) {
Help please. |
Posted: Wed May 23, 2007 1:54 pm |
1. Add the 'ERRORS' parameter to your #use rs232() statement.
2. Don't put a printf() inside your #int_rda routine. It takes too long
to send all those bytes. It blocks rda interrupts from being processed
while it is sending those bytes. If interrupts are blocked, the incoming
bytes can't be removed from the UART receiver. It will then get an
overrun error. Without the ERRORS statement, the overrun error
will cause the UART receiver to lock-up. It won't work. |
tesla80
Posted: Wed May 23, 2007 3:02 pm |
Thanks,
Added errors but show up a warning (variable never used : rs232_errors)
| Code: | | #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS,restart_wdt) |
in int_rda:
| Code: | #int_RDA
void RDA_isr() {
S=getc();
in main
| Code: | | if(S=='p') printf("ok\n"); |
but still it doesn't work.
i apply on rx and tx pins 5V, but doesn't interrupt...
and schema :
tesla80
Posted: Wed May 23, 2007 4:35 pm |
it's working with your code
#fuses HS, NOWDT, BROWNOUT, PUT, NOLVP
#int_rda
void rda_isr(void)
char c;
c = getc(); // Get character from PC
putc(c); // Send it back to the PC
what is the difference? fuses? |
Posted: Wed May 23, 2007 4:42 pm |
You have TRISC.7 (Rx) set incorrectly. You're setting it as an output
and it must be set as an input pin. |
tesla80
Posted: Wed May 23, 2007 4:52 pm |
yes, you are right. I wouldn't think this.
SET_TRIS_C(0b10000000);
TRISC=0x80;
Thanks, it's working good now!  |
sella Guest
Posted: Mon Jul 21, 2008 6:24 pm |
I'm doing a RF project using PIC18F252 as the receiver.There are 1 transmitter and 2 receivers. When i use the sample program EX_SISR.C, the data sent was received and displayed in virtual terminal. I need to use the received data to compare with another data to detect either it is same with receiver 1 or receiver 2.Then LED at receiver 1 or receiver 2 must be on.But now i am not able to compare the data.
Below are the sample code.
#if defined(__PCM__)
#include <16F877.h>
#elif defined(__PCH__)
#include <18F252.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,
#include <string.h>
#define G1_LED PIN_B2
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
int t;
buffer[next_in]=getc();
t=next_in;
if(next_in==next_out)
next_in=t; // Buffer full !!
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
return(c);
char Temp_Data;
char string[10]= "THSW1";
enable_interrupts(global);
enable_interrupts(int_rda);
printf("\r\n\Running...\r\n");
// The program will delay for 10 seconds and then display
// any data that came in during the 10 second delay
do {
delay_ms(10000);
while(bkbhit)
putc( bgetc() );
Temp_Data = bgetc();
if(strcmp(Temp_Data,string)==0)
output_high (G1_LED);
delay_ms(60000);
}while (TRUE);
I really need help here. This is my final year project...
Kindly please help me.
thanks |
Posted: Tue Jul 22, 2008 2:29 am |
A a comment, the 'variable never used RS232_ERRORS' warning, is just an annoyance of the compiler, and remember is only a _warning_. It does not in itself imply that anything is really wrong, it is just telling you this, so that if it is a variable that isn't used, you can possibly get rid of it, and save a small amount of RAM
If you add the 'errors' statement to the RS232 setup (which should be the default), the compiler does two things. First it adds to the getc code, routines to clear errors if set. Then it generates a variable called 'RS232_ERRORS', and when it clears an error, makes a copy of the error bits into this. Hence you can at any time read this variable, and see what the last error was. However if you don't read the variable, you get the warning, which 'worries' some people, who don't understand what is happening.
sella Guest
Posted: Tue Jul 22, 2008 7:44 am |
Hi! Thanks for the reply.
I tried to compare the data received with another data, but I still couldn't get the output desired. I can't understand why the data is not compared.
Please kindly reply.
thanks |
