16F505 Problem
16F505 Problem
PostPosted: Sat May 05, 2007 6:15 am     Reply with quote
Hi.
I want to use 16f505 but my code can not work. Would you help me please ? I want to use Timer0 and only one led flasher. Best regards.
#include <16F505.h>
#FUSES NOWDT, INTRC_IO, NOMCLR
#define  Led       PIN_B1
   int X=0;
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);  //1ms timer
   set_tris_b(0b00);
   set_tris_c(0x00);
   while (true)
       set_timer0(0);
       Output_high(PIN_B1);
       Delay_ms(1000);
       Output_low(PIN_B1);
       Delay_ms(1000);
       get_timer0();
       output_c(X);
PostPosted: Sun May 06, 2007 4:19 pm     Reply with quote
My code can not work:
get_timer0();
output_c(x);
You need to put the value from get_timer0() into X.
Do it like this:
x = get_timer0();
output_c(x);
PostPosted: Wed May 23, 2007 1:05 pm     Reply with quote
Hi Dear Friends..
My code is run but
Sometimes run and sometimes does not run. I thing sometime does not be POR reset. I do not undertand this problem. Please help me for I want to that everytime run this code but how? Best Regards..
#include <16F505.h>
#FUSES  INTRC_IO,NOWDT,NOMCLR,PROTECT
//#use rs232(baud=2400, xmit=PIN_B2, INVERT)
#define  Led       PIN_B1
int x
int   sin;
DELAY_MS(500);
      #asm
        clrw                 //clear W
        movlw  0xC6
        clrwdt              //; clear WDT
        option
        movlw  0b00000000
        TRIS    6
        movlw  0b00000000
        TRIS    7
        clrf   0x06
        clrf   0x07
      #endasm
   while (true)
       set_timer0(0);
       Output_high( Led );
       Delay_ms(1000);
       Output_low( Led );
       Delay_ms(1000);
       sin=get_timer0();
       output_c(X);
PostPosted: Fri May 25, 2007 2:07 am     Reply with quote
Please help me. I did not solve this problem.
PostPosted: Fri May 25, 2007 5:41 am     Reply with quote
Why did you make all the other changes instead of doing what you were asked by PCM to do?? I would advise you go back to the first code you posted and do exactly what PCM requested then let us know what happened.
Do it like this:
x = get_timer0();
output_c(x);
