18f452 External Interrupts Problem
jemly
PostPosted: Mon May 21, 2007 7:00 am     Reply with quote
I've written what I thought was some simple code to get an external interrupt working on a pic18f452 but my interrupt routine never ever gets hit and I don't know why although I'm guessing I haven't configures this properly. Here's the code:
#include "J:\My Documents\CCS Projects\GNSMotors02\main.h"
#define  LED0        PIN_B1
boolean pressed = false;
void led_on()
   output_high(LED0);
void led_off()
   output_low(LED0);
#int_EXT
void  EXT_isr(void)
   led_on();
   delay_ms(100); //debounce switch
   pressed = true;
void Do_States()
   if(pressed)
      //SetMotorPositions();
   //port_b_pullups(TRUE);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   //timer 2 set up for maximum frequency of 4MHz clock
   //4000000 / 1024  3906.25Hz
   setup_timer_2(T2_DIV_BY_1,255,1);
   //set up pwm outputs
   setup_ccp1(CCP_PWM);
   setup_ccp2(CCP_PWM);
   //initialise at 0% duty cycle
   set_pwm1_duty (0);
   set_pwm2_duty (0);
   //set up interrupt on B0
      clear_interrupt(INT_EXT);
      enable_interrupts(INT_EXT);
      ext_int_edge(0,H_TO_L);
   set_tris_b(11111101);
   port_b_pullups(00000001);
      led_off();
       Do_States();
I've got a non latching switch connected to port b pin 0 and it is normally high, going low when pressed (although reading the voltage at pin b0 when the switch is not pressed only gives me 1.7V - is this right?!); It does go to 0V when pressed. The EXT_isr routine never gets hit so the interrupt doesn't seem to be working at all. Any ideas why this is?
drh
PostPosted: Mon May 21, 2007 8:16 am     Reply with quote
Change this:
to this:
set_tris_b(0b11111101);
port_b_pullups(0b00000001);
David
Humberto
PostPosted: Mon May 21, 2007 9:03 am     Reply with quote
No. The voltage should be close to +5V.
Something wrong:
1) in your hardware
2) in the pin direction configuration
3) in the pull up resistor
It is not a good practice to use delays inside an interrupt handler !!!
To 'see' the RB0 interrupt action, the following code should be enough.
#int_ext
void EXT_ISR()
  output_low(LED0);
  pressed = true;
           your stuff
           if(pressed)
               delay_ms(200);
               output_high(LED0);
               delay_ms(200);
               pressed = FALSE;
Humberto
jemly
PostPosted: Wed May 23, 2007 4:25 am     Reply with quote
Thank you Humberto that's really useful!
