Tomson
| I2C bus causes reset |
Posted: Wed May 09, 2007 1:59 am |
I'd like to program a i2c bus between a pic and a DAC. The pic I'am using is a PIC18F2480 with hardware i2c. The DAC is a MAX5812L with the device adress 0x20.
My code is running until the first i2c_write() instruction. It seems to me, that the watchdog causes a reset of the pic after I´ve called this function.
My PCWH compiler version is 4.023.
Can anybody explain this error to me?
Here´s my code...
// I2C testprogram
// date: 09-May-2007
// software information:
// compiler: PCWH
// version: V4.023
// IDE: MPLAB V7.50
// hardware information:
// master: PIC18F2480 use of hardware I2C
// slave: MAX5812L write adress: 0x20
// read adress: 0x21
// I2C bus: pull up resistors in scl and sda (4k7)
// Header Dateien
#include "18f2480.h"
#define STATUS_LED1 PIN_C1
#define STATUS_LED2 PIN_C2
// I2C...
#define Cmd_PowerUp 0x40
#define Cmd_PowerDown0 0x44
#define Cmd_PowerDown1 0x48
#define Cmd_PowerDown2 0x4C
#define SLAVE_WRITE_ADRESS 0x20
#define SLAVE_READ_ADRESS 0x21
// Configuration Bytes
//#fuses H4,WDT128,PROTECT, BROWNOUT, BORV20, NOLVP, NODEBUG
#fuses H4, PROTECT
#fuses BROWNOUT
#fuses WDT128, BORV42
#fuses PUT, NOCPD, STVREN, NODEBUG
#fuses NOLVP, NOWRT, NOWRTD, NOIESO, FCMEN
#fuses NOPBADEN, BBSIZ1K, NOWRTC, NOWRTB, NOEBTR
#fuses NOEBTRB, CPB, NOLPT1OSC, MCLR
#fuses NOXINST
#use delay(clock=40000000)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use I2C(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW, STREAM=DAC)
#zero_ram
// lokals...
int i8_temp1, i8_outputhigh, i8_outputlow;
// set up´s
SETUP_ADC_PORTS(ALL_ANALOG);
SETUP_ADC(ADC_CLOCK_DIV_16);
SET_TRIS_A(0b11111111);
SET_TRIS_B(0b11001000);
SET_TRIS_C(0b00000000);
SETUP_TIMER_0(RTCC_8_BIT | RTCC_DIV_32 );
SETUP_WDT(WDT_ON);
// switch off the status led´s
OUTPUT_BIT(STATUS_LED1, 0);
OUTPUT_BIT(STATUS_LED2, 0);
delay_ms(20);
// main loop
do {
OUTPUT_BIT(STATUS_LED1, 1);
delay_ms(20);
// Power up slave device MAX5812L
I2C_START(DAC);
I2C_WRITE(SLAVE_WRITE_ADRESS); // device adress SLAVE_WRITE_ADRESS = 0x20
I2C_WRITE(Cmd_PowerUp); // device command Cmd_PowerUp = 0x40
I2C_STOP(DAC);
OUTPUT_BIT(STATUS_LED2, 1);
delay_ms(20);
i8_outputhigh = 0xFF;
i8_outputlow = 0xFF;
// output dac value...(12Bit)
i8_temp1 = i8_outputhigh & 0x0F;
i8_temp1 = 0xC0 | i8_temp1;
I2C_START(DAC);
I2C_WRITE(i8_temp1); // device command 0xC..+ 12 Bit data
I2C_WRITE(i8_outputlow);
I2C_STOP(DAC);
// Power down slave device MAX5812L
I2C_START(DAC);
I2C_WRITE(Cmd_PowerDown0); // device command Cmd_PowerDown0 = 0x44
I2C_STOP(DAC);
delay_ms(20);
restart_wdt(); // restart watchdog timer
} while (TRUE);
Thank you.
Tomson[/code] |
Posted: Wed May 09, 2007 12:20 pm |
| Quote: | My code is running until the first i2c_write() instruction.
Notice the line in bold above. Then read this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=29935 |
Tomson
| I2C bus problem obviously solved! |
Posted: Thu May 10, 2007 2:20 am |
Hello PCM Programmer,
thanks for your fast reply. Obviously the problem is solved. But I have to change the #use i2c instruction too.
The following code (snipped) does work well.
#use I2C(Master, sda=PIN_C4, scl=PIN_C3, STREAM=DAC)
SET_TRIS_C(0b00011000);
Thanks again.
Best regards
Tomson |
