| Software I2C master problem |
Posted: Thu May 03, 2007 7:40 am |
The device hangs up when I do not use the I2C hardware pins.
When I use PIN_B6 for SCL it works, and pin A4 is toggling, so do the I2C pins.
When I use PIN_B7 (or any other pin) for SCL there is no activity on pin A4 or the I2C pins.
Any ideas?
I need to use software I2C, I will later on use 2 I2C ports...
| Code: | #include <16F690.h>
#device adc=8
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#use delay(clock=8000000)
#define SC_SDA PIN_B4
#define SC_SCL PIN_B6
#use i2c(Master, sda=SC_SDA, scl=SC_SCL, slow, STREAM=SC1 )
int16 x;
int8 y;
set_tris_a(4);
output_a(4);
while(TRUE) {
x = 12345;
y = 12;
i2c_start( SC1 );
i2c_write (SC1, make8(x,1));
i2c_write (SC1, make8(x,0));
i2c_write (SC1, y);
i2c_stop( SC1 );
output_low(PIN_A4);
delay_ms(50);
output_high(PIN_A4);
delay_us(10);
Posted: Thu May 03, 2007 7:45 am |
This works!
#define SCENECAM_SDA PIN_C6
#define SCENECAM_SCL PIN_B4
This makes the compiler hang!
#define SCENECAM_SDA PIN_B4
#define SCENECAM_SCL PIN_C6 |
Posted: Thu May 03, 2007 7:52 am |
| C0 and C1 does not work together either! :( |
rnielsen
Posted: Thu May 03, 2007 9:00 am |
| Quote: | #use i2c(Master, sda=SC_SDA, scl=SC_SCL, slow, STREAM=SC1 )
I2C statements do not use a 'Stream'. This is for defining multiple RS232 ports. Try taking that out of your #USE statement and see what happens.
Ronald |
strombom
Posted: Fri May 04, 2007 12:57 am |
According to the manual it does:
STREAM=id
Associates a stream identifier with this I2C port. The identifier may then be used in functions like i2c_read or i2c_write.
I also got this answer from support before I bought the compiler:
Do something like:
#use i2c(Master,Slow,sda=PIN_B4,scl=PIN_C6, STREAM=ONE)
#use i2c(Master,Slow,sda=PIN_C0,scl=PIN_A2, STREAM=TWO)
i2c_start( ONE );
rnielsen
Posted: Fri May 04, 2007 10:30 am |
Okay, I don't use Version 4 yet because of the bugs and Stream was not an option in V3.xxx.
Ronald |
