DKH Guest
external ADC |
Posted: Tue May 01, 2007 12:22 pm |
Does anyone here have an example how to conect and program an external ADC(for example ADC0804)?
tks
Nina |
SherpaDoug
Posted: Tue May 01, 2007 1:41 pm |
Start with EX-AD12.C in your examples folder. It uses either the LT1298 or the MCP3208 converters, but it is a place to start. _________________ The search for better is endless. Instead simply find very good and get the job done. |
nina
external adc |
Posted: Tue May 01, 2007 2:43 pm |
thanks SherpaDoug....do you have any example showing how to conect and program this devices?
tks
Nina |
Posted: Tue May 01, 2007 2:58 pm |
One question would be, why do you want to use an external 8-bit A/D
chip when your PIC likely has an internal 10-bit A/D ? |
nina
external ADC |
Posted: Tue May 01, 2007 3:25 pm |
PCM programmer..
My load cell has 10000 lbs (at full load) if I have a 10 bits ADC I just have 1024 reading then I would have reading like...10, 20, 30,40,50...100,110,120,130...until 10000 lbs. I need more precision thats why I need use an external ADC
tks
nina |
Humberto
Posted: Tue May 01, 2007 9:32 pm |
You will find how to connect the ADC0804 to any uP it in the datasheet.
It has 8 bit paralel output [DB0...DB7] ChipSelect, Read, Write and an Interrupt
signal that will give a down level at the end of conversion cycle.
It is quite old and it will be out of spec according to your project needs.
The point is, as PCM Programmer said, why are you trying with an external 8
bit ADC while you already have a built in 10 bit ADC module inside the PIC.
To get a monotonic reading increment of 1 lb you will need a resolution of 14 bits.
Humberto |
nina
external ADC |
Posted: Wed May 02, 2007 6:53 am |
sorry humberto...I missed when I sad ADC0804. I intend use a ADC (at least 16 bits resolution).
Thanks for explanation about how to conect external ADC, I will check and if I have some doubt I will post here.
About programming PIC to get reading from external ADC. Do I just need do this or do I need something else?
setup_adc_ports(ALL_ANALOG);
delay_ms(5);
printf("-------Ready to read-----");
while (TRUE)
set_adc_channel(0);
delay_us(20);
valor1=read_adc();
delay_us(30);
printf(")%4.0f ->%1.2f :::",valor1,volt1);
printf(lcd_putc,"%2.2f",valor1);
Tks
nina |
