faizanbrohi
| LCD Problem |
Posted: Sun Apr 22, 2007 12:58 am |
Hello , i just bought a LCD with Blue Black light . the LCD is GDM1602A . the datasheet is here [url] http://users.ece.gatech.edu/~hamblen/UP3/GDM1602A.pdf [/url] , i have tried everything to run it , but it just displays boxes on the LCD screen and it flickers when it gets data , but no character is displayed , what could be the problem . Here is the code
| Code: | #include <16F628.h>
#FUSES XT //Crystal osc <= 4mhz
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES NOMCLR //Master Clear pin enabled
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#FUSES NOLVP
//#use rs232(baud=9600,parity=N,xmit=PIN_A3,rcv=PIN_A2,bits=8)
#define D0 PIN_A0
#define D1 PIN_A1
#define D2 PIN_A2
#define D3 PIN_A3
#define D4 PIN_A4
#define D5 PIN_A5
#define D6 PIN_A6
#define D7 PIN_A7
//#define LCD_TYPE 2
#include <LCD.c>
output_high(D0);
output_low(D0);
output_high(D0);
While(TRUE){
output_high(D0);
lcd_init();
lcd_putc("\fHello World...");
output_low(D0);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
i think that by looking at the datasheet , the DDRAM Address for accessing the character might be different , so how should i add this in LCD.c |
GoodEmbed'
Posted: Sun Apr 22, 2007 5:54 am |
lcd_putc expects only one char at a time as far as I know. I use my tutors LCD driver, but I except its functionally the same.
Try | Code: | | printf(lcd_putc,"\fHello, World!"); |
I noticed that although you've defined the pins for the data connection, you have not connected up the control lines RW/RS/EN. |
faizanbrohi
Posted: Sun Apr 22, 2007 11:26 am |
| No i have connected the RS/RW/EN pins and data pins also , it is defined in LCD.c . So no problem there . still i don't think so the statement is going to change anything . It is displaying boxes , i.e it is not reading data. , or is not synchronized , but i have checked the data pins and RS/RW/EN pins , they are transmitting data. , what could be the problem. |
GoodEmbed'
Posted: Sun Apr 22, 2007 11:35 am |
AH ha!
you're using port A!! (I thought you were using port D from your notation - but 16f628 is a small device of course)
Pin A5 cannot send data.
lame, I know. Check the data sheet and use the bookmarks on the left to find section 5.0 (I/O) to read up on the matter. |
Posted: Sun Apr 22, 2007 11:37 am |
1. Where does the "LCD.c" file come from ? Is it the CCS driver ?
2. What pins are you using for the LCD ? Post the list of connections
between the PIC pins and the LCD pins.
3. Do you have a trimpot on the LCD's contrast pin ? What voltage
have you applied to the contrast pin ? |
faizanbrohi
Posted: Sun Apr 22, 2007 12:01 pm |
I am using the Default Port B for the PIC16F628 . i have tried the LCD.c Driver supplied by CCS , the pin connection is as follows ,
PIC PIN6/B0 ---> LCD PIN 6/EN
PIC PIN7/B1 ---> LCD PIN 4/RS
PIC PIN8/B2 ---> LCD PIN 5/RW
PIC PIN10/B4 ---> LCD PIN 10/D4
PIC PIN11/B5 ---> LCD PIN 11/D5
PIC PIN12/B6 ---> LCD PIN 12/D6
PIC PIN13/B7 ---> LCD PIN 13/D7
10k trimpot used for contrast . and the contrast is adjusting perfectly i.e when not connected to pic it displays boxes in 1 line and i can change the contrast easily by varying the trimpot . As for the Backlight , it is also connected. i have also used another driver for the LCD for the Samsung controller based LCD posted on this forum but no result . Could there be some problem with the driver. Please help , what could be the problem. |
Posted: Sun Apr 22, 2007 1:37 pm |
| Post your compiler version. |
faizanbrohi
Posted: Sun Apr 22, 2007 9:16 pm |
| it is 4.018 |
Posted: Mon Apr 23, 2007 12:25 am |
I can test this tomorrow, but my advice is to use the Flex LCD driver
in the Code Library. It's more likely to work, and it's easier than trying
to setup the CCS driver. |
faizanbrohi
Posted: Mon Apr 23, 2007 8:50 am |
I have tried the Flex LCD Driver , with this driver the LCD shifts to the second line but no characters are displayed. i have checked everything , and i have changed the pin configration accordingly also . what i am guess is that my LCD is 5x8 dots and it has a different address for characters , that might be the problem please can you see this and tell me if that is the problem , the DDRAM Address is given in the LCD Datasheet. it is located here http://users.ece.gatech.edu/~hamblen/UP3/GDM1602A.pdf
Thank you |
faizanbrohi
Posted: Mon Apr 23, 2007 8:14 pm |
| Still it shifts to the next line partly distorted i.e , the second line blocks are half filled but still nothing only boxes appear., have checked with every time delay. what could be the problem. |
Posted: Tue Apr 24, 2007 12:35 am |
Maybe you should try a different LCD. In this thread here, we go on
and on with him, and finally he buys a different LCD and corrects a
problem with the connections and it starts working:
http://www.ccsinfo.com/forum/viewtopic.php?t=22713
This thread has more help on getting an LCD working:
http://www.ccsinfo.com/forum/viewtopic.php?t=30026
Also, there are some things in your posted code that are not correct,
such as the commenting out of NOLVP:
The NOLVP fuse needs to be put back in. |
faizanbrohi
Posted: Tue Apr 24, 2007 1:06 pm |
| the NOLVP fuse is on , check the code again . but i still did not find any solution , now i am trying to change the LCD or mail the manufacturer for a complete datasheet and then build my own driver for the LCD. the controller is the S6A0069 or the KS0066U . |
faizanbrohi
Posted: Wed Apr 25, 2007 8:38 am |
| This is turning out to be a mysterious problem , i have changed the LCD and now i am using a simple 16x1 LCD , and still boxes appear on the LCD. something wrong with the chip or the program , what should i do. |
