nina
load cell |
Posted: Sat Apr 21, 2007 8:38 am |
I have a load cell as sensor (range output 0 to 2 mV/V).
I want develop a project using PIC to mesure weight and show over LCD or display. Does anybody here can help me?
I have some knowledge about PIC, electronic, a programming.
Thanks a lot |
libor
Posted: Sat Apr 21, 2007 9:10 am |
You'll have to use a precision op-amp, or a hi-res ADC, or both (the PICs built-in ADCs have not enough resolution for this)
Look for AN1030 on the Microchip website for some clues here |
load cell |
Posted: Sat Apr 21, 2007 1:41 pm |
thank you for explanation...but how I will read an external ADC like AN1030?
yours |
libor
Posted: Sat Apr 21, 2007 1:59 pm |
Do you want to make a real working calibratable digital weigh scale ? What range/precision is required ? Or is this just a hobby example project you are thinking of to put together ?
I am asking this because the precise and repeatable measurement in the mV resolution (a load cell output) is not only a difficult task from the programming point of view (filtering algorythm, calibration, etc.) but also requires experince with analog signal conditioning circuitry like low-noise op-amps, high resolution ADC, etc.
The external A/D converter mentioned in that application note has an SPI bus interface. |
load cell |
Posted: Sat Apr 21, 2007 2:05 pm |
thanks again with your explanation...
first I would like just build a project like...
sensor (load cell).....external ADC....PIC...display or LCD..
After this work...I will try improve it to be better but first of all...I just want put in practice.
Thanks again |
load cell |
Posted: Sun Apr 22, 2007 7:13 am |
Does anyone here have an example about a project using any kind of external ADC?
Thanks a lot |
Posted: Sun Apr 22, 2007 3:21 pm |
Hint. Look in the files that come with the compiler...
EX_AD12.c, reads values using the supplied driver for two 12bit ADC's.
There is also a driver for the AD7715 16bit ADC, designed for exactly your sort of application.
