mohikan
Posted: Sun Apr 15, 2007 3:26 am |
I had a similar project, the LEDs were connected to port RA (RA2=LED Blue, RA3=LED Red, RA4=LED Green) each with its own resistor (RA4 needs pull-up), the software PWM is in timer2 ISR and it's from a Microchip MicroSolutions Newsletter.
#include "RGBTest.h"
#INT_TIMER2
void TIMER2_isr()
#asm
movf pwm_counter,w
subwf pwm_duty_green,w
rlf output,f
movf pwm_counter,w
subwf pwm_duty_red,w
rlf output,f
movf pwm_counter,w
subwf pwm_duty_blue,w
rlf output,f
rlf output,f
rlf output,w
movwf PORTA
incf pwm_counter,f
clrf output
#endasm
#inline
void set_pwm_duty(ColorType color,int duty)
switch(color)
case RED:
pwm_duty_red=duty;
case GREEN:
pwm_duty_green=duty;
case BLUE:
pwm_duty_blue=duty;
default:break;
set_tris_a(0x21);//00100001
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,0x4E,1);
setup_vref(FALSE);
setup_ccp1(CCP_OFF);
printf("\n\rRGBTest v1.0 2006\n\r");
switch(getc())
case '7':
++pwm_duty_red;
set_pwm_duty(RED,pwm_duty_red);
case '4':
--pwm_duty_red;
case '8':
++pwm_duty_green;
set_pwm_duty(GREEN,pwm_duty_green);
case '5':
--pwm_duty_green;
case '9':
++pwm_duty_blue;
set_pwm_duty(BLUE,pwm_duty_blue);
case '6':
--pwm_duty_blue;
default:break;
printf("> R:%03u G:%03u B:%03u\r",pwm_duty_red,pwm_duty_green,pwm_duty_blue);
#include <16F628A.h>
#FUSES PUT //Power Up Timer
#use rs232(baud=19200,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,stream=UART)
#use fast_io(a)
#define PORTA 0x05
typedef enum
RED,
GREEN,
BLUE
} ColorType;
unsigned int pwm_counter=0;
unsigned int pwm_duty_red=0;
unsigned int pwm_duty_green=0;
unsigned int pwm_duty_blue=0;
unsigned int output=0;
