		| Author | Message |
		| sebdey
				| memcpy and const tables |
				|  Posted: Wed Mar 28, 2007 7:51 am |   |
				| Hello, I am developing an application with a graphical LCD, and am running into the problem of displaying bitmaps on my lcd.
 I want to store my bitmaps in rom using a #rom statement. But I then cannot retrieve the correct data using memcpy. Here's my code:
 Bitmap declaration and storage
  	  | Code: |  	  | #define  LOGO 0x0F000
 #rom int8 LOGO = {0xFF, 0xFF, 0xFF, 0xE0, 0xE0, 0xFF, 0xFF, 0xFF,
 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}
 In main, after lcd initialisation etc...
  	  | Code: |  	  | ...
 glcd_drawbitmap(90,30,LOGO,8,16);
 The glcd_drawbitmap routine
  	  | Code: |  	  | void
 glcd_drawbitmap(int x, int y, int32 bitmapAddress, int width, int height)
 int bitmapData[1024];
 int *bitmapPointer=bitmapData;
 int i,j,k;
 height=height>>3;
 memcpy(bitmapPointer, bitmapAddress, width*height);
 for(i=0;i<height;i++)
 for(j=0;j<width;j++)
 for(k=0;k<8;k++)
 if(bit_test(*bitmapPointer,k))
 glcd_pixel(x+j,y+(i<<3)+k,ON);
 glcd_pixel(x+j,y+(i<<3)+k,OFF);
 bitmapPointer++;
 This will only output garbage (and always the same garbage) on my lcd, I suspect the memcpy to not copy the correct area of my flash into the bitmapData table. What am I doing wrong ? I searched the forum for memcpy and #rom, but nothing really helped me...
		| PCM programmer
				|  Posted: Wed Mar 28, 2007 11:29 am |   |
				| Make a small test program where you test only the memcpy() function.   Study the function documentation.   Look at the .LST file
 to see what it's doing.
 By a small program, I mean less than 6 lines of code in main().
 Concentrate on fixing the memcpy() problem only.   Don't write
 to the LCD.   Don't #include the LCD driver files.    Use printf()
 to a terminal window for output.   Keep it very simple.
 If you can't solve it, then post your test program.   Be sure to post
 all the #include, #use and #fuses statements.   Also post your compiler
 version.
		| me, sebdey Guest
				|  Posted: Thu Mar 29, 2007 12:43 am |   |
				| Thanks PCM, but here I am not looking for a lesson but an answer from someone who could reduce my development time...
 I have already solved my problem by other means, i.e. declaring the arrays as:
  	  | Code: |  	  | #define LOGO_ID   0
 const int8 LOGO[16] = {0xFF, 0xFF, 0xFF, 0xE0, 0xE0, 0xFF, 0xFF, 0xFF,
 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
 #define BITMAP1_ID   1
 const int8 BITMAP1[length] = {data...};
 #define BITMAP2_ID   2
 const int8 BITMAP2[length] = {data...};
 and then reading them in my glcd_drawbitmap by using:
  	  | Code: |  	  | (...)
 switch (bitmapID)
 case LOGO_ID:
 memcpy(bitmapPointer,LOGO, width*height);
 case BITMAP1_ID:
 memcpy(bitmapPointer,BITMAP1, width*height);
 But even if this is working, it's not what I want. If no one is willing to give me a short and quick answer, I don't want to lose time trying things that I already tried for hours.
 I have done tests with memcpy and standard ram arrays and also with const rom arrays and it works, but no chance with a #rom memory definition... Maybe is this completely impossible and I should resolve it with a read_program_memory or my current solution...
 Have a good day...
		| kevcon
				|  Posted: Thu Mar 29, 2007 7:40 am |   |
				| Because CCS dosen't handle ROM pointers correctly ( yet? ), You have to fake it out and write your own routines.
 This is geard towards PIC18s, it may work for you, but I don't know for sure because I don't know what chip you are using.
  	  | Code: |  	  | #define TBLPTRU 0xFF8
 #define TBLPTRL 0xFF6
 #define TABLAT   0xFF5
 #byte   _TBLPTRU = TBLPTRU
 #byte   _TBLPTRL = TBLPTRL
 #byte   _TABLAT = TABLAT
 void rom_to_ram_memcpy(int8 *ramptr, int8 *romptr, int16 numberofBytes);
  	  | Code: |  	  |
 #define  LOGO 0x01000
 #rom int8 LOGO = { 0x12, 0x34 }
 int8 bitMapData[ 16 ];
 void main( void )
 int8 *bitMapPointer = bitMapData;
 rom_to_ram_memcpy( bitMapPointer, LOGO, 2 );
 char *_TBLPTR;
 #locate _TBLPTR = TBLPTRL
 //Setup ROM TABLE Pointer
 _TBLPTRU = 0x00;
 _TBLPTR = romptr;
 for (; numberofBytes-- ; ramptr++ ) {
 #asm
 TBLRD   *+
 #endasm
 *ramptr = _TABLAT;
		| _sebdey Guest
				|  Posted: Thu Mar 29, 2007 8:53 am |   |
				| Thanks for your answer kevcon !
 I will then have to see which method is the best for my project in terms of ease of use/implementation/scalability....
 Btw, my fault, I forgot to mention that I am using 18F4620, and 3.235...
 Have a good day/night/evening !
 | You cannot post new topics in this forum You cannot reply to topics in this forum
