		| View previous topic :: View next topic   |
			kender
				| [resolved] Can’t start PIC18F4220 with internal oscillator |
				 Posted: Sat Mar 24, 2007 4:35 am     |
				Colleagues,
I can’t seem to get the PIC18F4220 with an internal oscillator going.  Debugger gives a “Could not start target:…” message.  Could you take a look at my fuses, please?
CCS v3.240
PIC18LF4220 (TQFP-44)
ICD-U40
Test ICD – pass
Test target – pass
Error message: Could not start target:…
After the message, MCLR#  = Vcc = +4.1V. Pulled up by 43k resistor (I just didn't have 47k among my supplies)
OSC1 and OSC2 pins are unconnected at the moment, but eventually they will be used for I/O
#include <18F4220.h>
#device ICD=TRUE
#device adc=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9,stream=pcrs232)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3) |
Cheers,
Nick
			mskala
  Joined: 06 Mar 2007 Posts: 100 Location: Massachusetts, USA
				 Posted: Sat Mar 24, 2007 8:53 am     |
				Hi, I was recently trying to look at proper debug settings in case I buy one.
Not that I know it very well yet, but all your fuses look good to me except IESO.  Since that mode is supposed to use INTOSC until some external clock source is ready, it's not clear to me what will happen if you set this fuse along with actually using the INTOSC.
Keep us posted
Mark S. |
			kender
				| IESO fuse |
				 Posted: Sat Mar 24, 2007 8:37 pm     |
				 	  | mskala wrote: | 	 		  | Not that I know it very well yet, but all your fuses look good to me except IESO.  Since that mode is supposed to use INTOSC until some external clock source is ready, it's not clear to me what will happen if you set this fuse along with actually using the INTOSC. |
Thanks, Mark!  I have commented out the IESO fuse, but it didn't help.  I'm getting the same "Could not start target:…" message.
Could anyone post a combination of fuses (may be not for 18LF4220, but for some other PIC) that worked with the internal oscillator?
UPDATE: The following fuses produce the same "Could not start target:…" message.
 	  | Code: | 	 		  | #fuses INTRC, NOWDT, NOPROTECT, NOLVP |
Could this be a hardware issue? |
				 Posted: Mon Mar 26, 2007 11:52 am     |
				 	  | Quote: | 	 		  After the message, MCLR# = Vcc = +4.1V.
Pulled up by 43k resistor (I just didn't have 47k among my supplies) |
1.  I would change the Vdd voltage to +5v and see if it starts working.
2.  I would also add a 3.9K resistor in series with the 43K, just to make
     everything be perfectly within CCS spec. |
			kender
				 Posted: Mon Mar 26, 2007 11:59 am     |
				 	  | PCM programmer wrote: | 	 		  | 1.  I would change the Vdd voltage to +5v and see if it starts working. |
I have increased the Vcc to +5V, but it didn't make any difference.
 	  | PCM programmer wrote: | 	 		  2.  I would also add a 3.9K resistor in series with the 43K, just to make
I will try this too.
My problem might be caused by the ICD firmware.  I have e-mailed CCS support with the original question.  Here's their response.
 	  | CCS support wrote: | 	 		  | What is your ICD firmware version? If you open the ICD control program(ICD.exe) it is displayed on the bottom status bar. We have this issue in versions above 2.05 [mine is v2.14]. Let me know the version and I am attaching 2.05. You need to switch back to this version when debugging this family. We are looking into the issue with the latest version. |
Unfortunately, my ICD control program refuses to upgrade the firmware, but that's a separate problem. |
