Hex to float
Goto page Previous  1, 2
Need Help
PostPosted: Thu Mar 22, 2007 12:18 am     Reply with quote
Hi Ttelmah,
i'm able to output the values using scaled integer when i using the printf only. However when i use the printf with tx_putc, there is no output in hyperterminal.
PostPosted: Thu Mar 22, 2007 1:08 am     Reply with quote
#define TX_BUFFER_SIZE (32)
int8 tx_buffer[TX_BUFFER_SIZE],tx_out=0,tx_in=0;
#define tx_empty (tx_out==tx_in)
#define incbuff(x) ((x+1) & ( TX_BUFFER_SIZE -1) )
#define tx_full (incbuff(tx_in)==tx_out)
If the buffer size is a power of 2, the bitmask should be the
buffer size -1. So I think you have to subtract one from
it, as shown above in bold.
Need Help
PostPosted: Thu Mar 22, 2007 1:52 am     Reply with quote
I m managed to obtain my output using the EX_STISR.C example. Thanks!
Page 2 of 2
