What is the proper way to turn PWM pin on and off?
Stuffed-Bit
PostPosted: Tue Mar 13, 2007 8:11 am     Reply with quote
Chip = 16F877A
Compiler = 3.155
Say I want to beep out some Morse code using the PWM pin C2. I set the PWM to 50% at 1KHz. Now what is the proper way to toggle the PWM on and off?
I "thought" I used to simply set pin_c2 high or low but that don't seem to work. Now I'm sending a setup_ccp1(CCP_PWM) to turn it on and a setup_ccp1(CCP_OFF) to turn it off. Is this the best way to do this or is there some thing better. I guess I could set the duty to all or none but then I have to remember where to go back to. What is you thoughts?
treitmey
PostPosted: Tue Mar 13, 2007 8:14 am     Reply with quote
That is the correct way.
newguy
PostPosted: Tue Mar 13, 2007 11:30 am     Reply with quote
You could leave the PWM on but switch the PIC's pin from being an output to an input and vice versa to toggle the PWM on/off. Just set/clear the appropriate bit in the PIC's TRIS register. I use this approach to burst/silence an IR LED to send command codes to A/V equipment with great success.
Stuffed-Bit
PostPosted: Tue Mar 13, 2007 9:18 pm     Reply with quote
Version 1 uses a few less commands than version 2 and produces the same results. Any reason not to use version 1 as long as the pin is pulled high or low and not left floating?
Also, is there a easier/quicker way to toggle tris for just pin_c2 with the set_tris_c(x) command without affecting other pins on port C? Or in other words is there a way to set a single bit using the set_tris_c(x) command?
//Version 1
output_high(pin_c2);  //enable PWM
delay_ms(duration);   //wait
output_float(pin_c2); //disable PWM
//Version 2
setup_ccp1(CCP_PWM);  //enable PWM
setup_ccp1(CCP_off);  //disable PWM
newguy
PostPosted: Tue Mar 13, 2007 11:24 pm     Reply with quote
#bit pwm_out_enable = 0xf94.2
[Of course, check your PIC's data sheet to ensure you're correctly mapping this bit.]
To enable PWM:
pwm_out_enable = 1;
To disable it:
pwm_out_enable = 0;
Also be sure to use the fast_io directive with the port you're using (probably port c):
#use fast_io(c)
Charlie U
PostPosted: Wed Mar 14, 2007 6:28 am     Reply with quote
Another way would be to change the duty cycle to 0%. This way, a pulse in progress would not be cut short. The PWM will continue to run, but with 0 on time. Then to start it up again, just set the duty cycle to 50%.
Charlie
