| changing output voltage |
Posted: Mon Mar 12, 2007 3:20 pm |
| I'm working with the 16f877 and am looking for a quick way to set the output voltage level between 0 and 5 volts. Does anyone know how to do this or point me to some example code? |
Posted: Mon Mar 12, 2007 3:35 pm |
Directly, you cannot do this. The PIC, only has _logic_ outputs. However you can get close, using one of the PWM pins, feeding into a simple resistor/capacitor integrator. Provided your load is quite a high impedance, and the resistor chosen is large, good results from perhaps 0.4 to 4.6v can be obtained.
Humberto
Posted: Mon Mar 12, 2007 7:30 pm |
You can drive a digital potentiometer (connected between Gnd and +V) using a PIC.
In the potentiometer cursor tap you will get an analog output in the range of 0 to 5V,
if you an need an output with more current and lower impedance, it is a matter of
connecting a transistor or an unity gain op amp in voltage follower configuration.
Humberto |
jecottrell
Posted: Mon Mar 12, 2007 9:56 pm |
If you do use a Digipot read the spec sheet for the current limits on the taps. Microchip parts a 1mA max on the center tap. That's bitten me several times. Now I remember to use a buffer.
John |
