xokolatecake
| unable to communicate with pic16f877a through rs232 |
Posted: Fri Mar 09, 2007 7:59 am |
I'm trying to communicate via rs232 with a 16f877a for the first time and i can't get anything. this is the code i'm using:
#include <16F877.h>
#device ADC=8
#include <stdio.h>
#fuses PUT, XT, NOWDT, NOLVP, NOBROWNOUT
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, bits=8, parity=N, errors)
void main() {
int8 x;
bit_set(x,0);
SETUP_ADC_PORTS(NO_ANALOGS);
SETUP_ADC(ADC_OFF);
SETUP_TIMER_0(RTCC_INTERNAL|RTCC_DIV_1);
SETUP_TIMER_1(T1_DISABLED);
SETUP_TIMER_2(T2_DISABLED, 127, 1);
//SETUP_TIMER_3(T3_DISABLED);
SETUP_CCP1(CCP_OFF);
SETUP_CCP2(CCP_OFF);
enable_interrupts(INT_RDA);
output_high(PIN_A0);
while (TRUE) {
putc('U');
if(bit_test(x,0)){
output_low(PIN_A0);
bit_clear(x,0);
else{
bit_set(x,0);
i'm using hyperterminal with settings 8,N,1
what am i missing?
thanks a lot;) |
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
Posted: Fri Mar 09, 2007 8:08 am |
what I think is missing is that you enable the int_rda interrupt, but you do not have any code handling the interrupt.
try a code as this:
| Code: | #int_rda
void rs232handling()
c = getc();
(with this example you also need to add a global variable: char c)
I hope this helps,
Cheers, Jos |
Humberto
Posted: Fri Mar 09, 2007 8:15 am |
| Quote: |
what am i missing?
You are missing to write a code to echoing a received character, that should be
the first attempt to comunicate.
Your code only print the letter "U" and toggle the PIN_A0.
If you search in this forum, for sure you will find hundreds of examples like this:
#include <16F877.h>
#device ADC=8
char c;
c = getc();
putc(c);
Humberto |
Posted: Fri Mar 09, 2007 9:22 am |
thanks for the help,
i have tried booth suggestions and it didn't work!
is there anything else i can try?...i'm using a max232 for level shifting and i have checked the connections several times i don't see here the problem is...
thanks a lot. |
xokolatecake
Posted: Fri Mar 09, 2007 9:24 am |
| Quote: |
thanks a lot.
i wrote this, just forgot to log on;) |
Humberto
Posted: Fri Mar 09, 2007 10:11 am |
Did you check your hardware? Check if the 232 level converter generate the appropiate
+V and -V voltages. In the regular ICL232/MAX232 converter type, they are PIN2 and PIN6.
Also, try with another terminal emulator, Hiperterminal + Window$... is not the best
choise to test RS232 communications. Most users reported negative comments here.
Humberto |
xokolatecake
Posted: Fri Mar 09, 2007 11:13 am |
thanks a lot for your answer,
i read 9V on V+ pin and -11V on V- pin, which i belive to be fine(according to data sheet). i have tried eltima's advanced serial port terminal and the serial port monitor that is part of ccs ide, and the result is the same:no data transfer!
i don't know what else to do..let me just make a few questions to clear my mind out:
-the pins not at use on the 232 chip should be grounded?
-the crystal i'm usong is not exactly 4mhz but close, does it matter?
-i only made 2connections between the pic and the 232 chip, pins rc6 and rc7, are those enough?
thanks a lot for your help |
rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
Posted: Fri Mar 09, 2007 11:34 am |
| Quote: | | -the pins not at use on the 232 chip should be grounded? |
You don't need to ground spare transmitter and receiver inputs
| Quote: | | -the crystal i'm usong is not exactly 4mhz but close, does it matter? |
You do need to accurately reflect your oscillator frequency. The compiler will use your #use delay command to calculate the correct values to write into the PIC's UART registers to give a certain baud rate. If what you put in the #use delay statement does not match your oscillator frequency, the baud rate generated will not be 9600 baud as you would like. That may be enough to print garbage or cause other odd things to happen.
| Quote: | | -i only made 2connections between the pic and the 232 chip, pins rc6 and rc7, are those enough |
Assuming you made the right connections, those two should be enough.
Have you looked at the output of the PIC/MAX232 with a scope, logic analyzer or something like that? If you are getting absolutely nothing at all, I'd check the output of the PIC AND that you have continuity in the RS232 cable AND that is the cable is the correct type (i.e. straight-through or NULL modem)
r.b. |
xokolatecake
Posted: Fri Mar 09, 2007 12:20 pm |
thanks for your answer,
i've tried with a 10mhz crystal, changing this part of the code:
#fuses PUT, HS, NOWDT, NOLVP, NOBROWNOUT
#use delay(clock=10000000)
and it didn't work...
i checked my cable and i got:
6-4,2-3,1-8,5-5 connections.
Does this look right to you? i could not find what kind of handshaking (loop-back,partial,full) my cable has...
thanks a lot for the help;) |
xokolatecake
Posted: Fri Mar 09, 2007 2:14 pm |
another thing,
i noted that my 232chip r1out(pin12) outputs 5v when not connected to the rc7 pin on the pic, and when i connect it, the voltage comes down to about 2v...is this a hint of something going wrong?
thanks a lot for all the help;) |
rberek
Posted: Fri Mar 09, 2007 2:34 pm |
Your explanation of your connections is not very clear, and without seeing your actual board, I can't really tell how you have things connected.
In your description, you say you have pin 2 connected to pin three. Pin 2 of what and Pin 3 of what? In a normal RS232 system Pin3 of the PC (DTE) is a Tx pin and pin 2 of a peripheral (DCE) is also Tx. These are both outputs and therefore no RS232 transaction will take place.
What you must do is ensure that there is connectivity between the Tx pin of the PIC and Pin 2 (Rx) of the PC's RS232 port. Check your MAX232 connection, its connection to the DB9 connector, and check the RS232 cable, which may have the Rx and Tx pins cross over on the way to the PC.
If the connection is correct, and nothing is happening, then you've got to trace the signal with something like an oscilloscope.
And the MAX232 inverts signals, so the behaviour you see is not necessarily unusual.
r.b. |
Humberto
Posted: Fri Mar 09, 2007 2:35 pm |
| Quote: |
Your cable should have the following connections:
2-3,3-2,5-5
| Quote: |
To comunicate a PIC with a PC it is not necesary any handshaking.
Use a cable as shown in the lower example:
http://www.isotech.co.uk/images/rs232.gif
Humberto |
gdl_pro
Posted: Fri Mar 09, 2007 4:11 pm |
This will help you debug your hardware first and then debug the real failure.
1.- disconnect you rs232 cable from your circuit and make a short in pins 2-3 of the cable. Use your hyperterminal to send text. Verify if the data is returned thru the short.
2. If cable works remove the short and reconnect it to the circuit and a short between pics C6 & C7 of the PIC. Use your hyperterminal to send text. Verify if the data is returned thru the short.
If both passsed thenm your hardware is correct and it is time to look deeper in the code or try a new chip. If not, then you can first solving the HW problems |
