krantz Guest
| flexible 4x4 keypad driver |
Posted: Thu Feb 08, 2007 8:01 am |
Hi to all!
Anyone used this driver within isr ( in my case INT_RB).
I can input only keys on first column (col0).
Any help?
Krantz |
treitmey
Posted: Thu Feb 08, 2007 9:25 am |
| Does it display results, but the wrong letter. OR nothing at all? |
krantz Guest
Posted: Thu Feb 08, 2007 11:16 pm |
Hi!
here the code in which during main, I to focus on keyboard input, it do a simple task.
The driver see only key press on first column of the matrix (col0) inputting however the right charachters ( I have '1' , '4' , '7' , 'A').
If I insert the call to kbd_getc(); directly in main ( as in the original example) without use of interrupt (int_rb) the driver work fine inputting all chars.
Many thanks!
#include "C:\Temp\TurboC\Mplab\16f877.h"
//Keypad connection:
#define row0 PIN_B4
#define row1 PIN_B5
#define row2 PIN_B6
#define row3 PIN_B7
#define col0 PIN_B0
#define col1 PIN_B1
#define col2 PIN_B2
#define col3 PIN_B3
char const KEYS[4][4] =
{{'1','2','3','F'},
{'4','5','6','E'},
{'7','8','9','D'},
{'A','0','B','C'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
void kbd_init()
//set_tris_b(0xF0);
//output_b(0xF0);
port_b_pullups(true);
short int ALL_ROWS (void)
if(input (row0) & input (row1) & input (row2) & input (row3))
return (0);
return (1);
char kbd_getc()
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR)
switch (col)
case 0:
output_low(col0);
output_high(col1);
output_high(col2);
output_high(col3);
case 1:
output_high(col0);
output_low(col1);
output_high(col2);
output_high(col3);
case 2:
output_high(col0);
output_high(col1);
output_low(col2);
output_high(col3);
case 3:
output_high(col0);
output_high(col1);
output_high(col2);
output_low(col3);
if(kbd_down)
if(!ALL_ROWS())
kbd_down=false;
kchar=last_key;
last_key='\0';
if(ALL_ROWS())
if(!input (row0))
row=0;
else if(!input (row1))
row=1;
else if(!input (row2))
row=2;
else if(!input (row3))
row=3;
last_key =KEYS[row][col];
kbd_down = true;
++col;
if(col==4)
col=0;
kbd_call_count=0;
return(kchar);
enable_interrupts(INT_RB);
kbd_init();
printf("\r\Starting ...");
output_high(PIN_d0);
delay_ms(300);
output_low(PIN_d0);
delay_ms(300);
#int_rb
int_rb_isr()
char k;
k=kbd_getc();
if(k!=0)
if(k=='*')
printf("%c", '*');
printf("%c", k);
treitmey
Posted: Fri Feb 09, 2007 8:35 am |
If it works by itself but not with the IRQ, then that would seem to be the problem.
Your int_Rb works by seeing a change on the upper nibble of port b. B4-B7...the rows
so in normal operation:
1. upper bits of port b are pulled up. These are the rows.
2. column are outputted as 0.
3. you press a key that will connect a row to column. That pulls a single row line to ground(0). That row(B4-B7) is seen by the IRQ. Then you can read/decode it.
I see you have two lines commented out in kpd_init.
Are you seeing any place in the code that doesn't look correct. |
krantz Guest
Posted: Sun Feb 11, 2007 11:57 pm |
Hi treitmey,
sorry for delay, but week end....!
The lines in keyb_init are commented in the original version of the driver and I got it as was, but after some tests it seems they shall be set in that mode to do work the driver .
To check for irq involvement on the problem, I've removed the int_rb and inserted the call to kbd_getc directly in main as shown.
In this test the driver doesn't capture any key press not even the keys on col0.
The only way I found to do work the driver is to remove also the on-off delay on
pin D0 as shown, and then the driver capture properly all the key presses .
I don't understand well how the driver works but it seems that it needs several passes to reach the condition (kbd_call_count>KBD_DEBOUNCE_FACTOR) and then decode the key.
Pheraps during the irq it doesn't has this chance, but I don't understand in the case of the on-off on pin D0 what could be the bug (perhaps the key press time width is less than 300+300 ms delay inserted !) .
Thanks again for support,
Krantz
#define row0 PIN_B4
#define row1 PIN_B5
#define row2 PIN_B6
#define row3 PIN_B7
#define col0 PIN_B0
#define col1 PIN_B1
#define col2 PIN_B2
#define col3 PIN_B3
{{'1','2','3','F'},
{'4','5','6','E'},
{'7','8','9','D'},
{'A','0','B','C'}};
void kbd_init()
//set_tris_b(0xF0);
//output_b(0xF0);
return (0);
return (1);
char kbd_getc()
static byte col;
byte kchar;
byte row;
kchar='\0';
switch (col)
case 0:
output_low(col0);
output_high(col1);
output_high(col2);
output_high(col3);
case 1:
output_high(col0);
output_low(col1);
output_high(col2);
output_high(col3);
case 2:
output_high(col0);
output_high(col1);
output_low(col2);
output_high(col3);
case 3:
output_high(col0);
output_high(col1);
output_high(col2);
output_low(col3);
if(kbd_down)
if(!ALL_ROWS())
kbd_down=false;
kchar=last_key;
last_key='\0';
if(ALL_ROWS())
if(!input (row0))
row=0;
row=1;
row=2;
row=3;
kbd_down = true;
++col;
if(col==4)
col=0;
kbd_call_count=0;
return(kchar);
kbd_init();
char k;
k=kbd_getc();
if(k!=0)
if(k=='*')
printf("%c", '*');
printf("%c", k);
//output_high(PIN_d0);
//delay_ms(300);
//output_low(PIN_d0);
//delay_ms(300);
