Ed_Banses
| Custom KeyPad Problem |
Posted: Thu Feb 08, 2007 8:44 am |
Hi all,
I am working now in a project where I have to interface a custom made KeyPad with a PIC.
KeyPad has each button connected straight to a PIC pin in one side and GND in the other side. There are 7 buttons.
I adapted the flexible keypad code to my project but I am getting problems.
The keys response is not good as some times I need to press more than once to get signal or keep the key pressed to read it.
Please find below my code:
#include <16F877A.h>
#device ICD=TRUE
#device *=16
#fuses HS, PUT, NOWDT, NOBROWNOUT, NOLVP//,NODEBUG, NOCPD, PROTECT
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#define DEBOUNCE 33
#define KEY_F1 PIN_B1
#define KEY_F2 PIN_B4
#define KEY_F3 PIN_B5
#define KEY_ENTER PIN_B2
#define KEY_UP PIN_B6
#define KEY_DOWN PIN_B3
int8 key;
//Functions to drive the KeyPad
void kbd_init()
port_b_pullups(true);
short int ALL_ROWS (void)
if (input (KEY_F1) & input (KEY_F2) & input (KEY_F3) & input (KEY_ENTER))
return (0);
return (1);
int read_keypad()
static BYTE kbd_call_count;
static short int kbd_down;
static char last_key;
BYTE kchar;
kchar = 0;
if(kbd_call_count++ > DEBOUNCE)
if(kbd_down) {
if(!ALL_ROWS()) {
kbd_down=FALSE;
kchar=last_key;
last_key = 0;
if(!input (KEY_F1))
last_key = 1;
else if(!input (KEY_F2))
last_key = 2;
else if(!input (KEY_F3))
last_key = 3;
else if(!input (KEY_ENTER))
last_key = 4;
kbd_down = TRUE;
return(kchar);
kbd_init();
printf("\n\rTry KeyKad");
key = 0;
while(key == 0){key = read_keypad();}
printf("\n\rKey pressed was: %u",key);
I will appreciate any help from you.
Thanks a lot in advance.
Kind Regards,
Eduardo |
Posted: Fri Feb 09, 2007 1:14 am |
The problem is that when you modified the code, you cut out some
lines that were needed. I compared your code to the original code
and fixed it. The lines that need to be added back in are marked
with comments below:
int read_keypad()
BYTE kchar;
kchar = 0;
if(kbd_down) {
if(!ALL_ROWS()) {
kbd_down=FALSE;
kchar=last_key;
last_key = 0;
if(ALL_ROWS()) { // Add this line
if(!input (KEY_F1))
last_key = 1;
last_key = 2;
last_key = 3;
last_key = 4;
kbd_down = TRUE;
} // Add this line
kbd_call_count = 0; // Add this line
return(kchar);
Ed_Banses
Posted: Fri Feb 09, 2007 3:48 am |
Thanks a lot PCM programmer!!!!
It works!!!!
You have save me again.
If you come to manchester at any time I will buy you a couple of pits ;)
Thanks again.
Kind Regards,
Eduardo |
