hadeelqasaimeh
| rs485 help |
Posted: Mon Jan 29, 2007 3:29 pm |
hi all;
i try to communicate using rs485 .
#define RS485_USE_EXT_INT FALSE
| ,,this line
supposed to use #int_rda (as i understand!!)
when i add this interrupt,,compiler returne this error message
duplicate interrupt function
i dont know whats wrong!
sorry for my bad language |
Posted: Mon Jan 29, 2007 3:34 pm |
The #int_rda function is already in the RS485.C driver file.
You don't need to add it.
Here is the location of the file:
c:\program files\picc\drivers\rs485.c |
hadeelqasaimeh
Posted: Tue Jan 30, 2007 1:22 am |
thank you PCM programmer
this is my test code [/code]
#include <16f877.h>
#include <string.h>
#fuses HS,NOWDT,NOLVP
#use delay(clock=20000000) //one instruction=1us
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,stream=pc)
PIN_C7 // Data receive pin
PIN_C6 // Data transmit pin
PIN_B4 // Controls DE pin. RX low, TX high.
PIN_B5 // Controls RE pin. Should keep low.
#define RS485_RX_BUFFER_SIZE 40
#define RS485_ID 0x01
#include "RS485.c"
#include "lcd_kbd1.c"
#define bkbhit (next_in != next_out)
int8 i, msg[RS485_RX_BUFFER_SIZE];
int8 next_in = 0;
int8 next_out = 0;
enable_interrupts(INT_RDA);
rs485_init();
LCD_Init ( );
// Purpose: Get a message from the RS485 bus and store it in a buffer
// Inputs: 1) A pointer to a buffer to store a message
// 2) TRUE - wait for a message
// FALSE - only check if a message is available
// Outputs: TRUE if a message was received
// FALSE if wait is FALSE and no message is available
// Note: Data will be filled in at the pointer as follows:
// FROM_ID DATALENGTH DATA...
if(rs485_get_message(* msg, TRUE))
LCD_PutCmd ( CLEAR_DISP );
LCD_SetPosition ( LINE_16_1);
printf(LCD_PutChar," MSG IS:");
LCD_SetPosition (LINE_16_2);
printf(LCD_PutChar,"%s",msg );
}//if
}//while
}//MAIN
will this print msg on lcd?without using #int_rda??
hadeelqasaimeh
Posted: Tue Jan 30, 2007 1:25 am |
sorry,this is my message agian:
#include <16f877.h>
#include <string.h>
#include "RS485.c"
int8 next_in = 0;
int8 next_out = 0;
rs485_init();
LCD_Init ( );
for(i=0; bkbhit && i<sizeof(msg); ++i)
msg[i] = bgetc();
}//if
}//while
}//MAIN |
will this print msg on lcd?without using #int_rda?? |
hadeelqasaimeh
Posted: Wed Jan 31, 2007 11:22 am |
| no one can help??!!plz |
