Simnix
| Reading in an RS232 barcode scanner |
Posted: Sun Jan 07, 2007 8:17 am |
Hi
I am trying to read in data coming from a barcode scanner and display the result on an 2x16 LCD, when I activate the scanner nothing happens, but, when I connect the barcode scanner to my PC and use "Hyper Turminal" it works OK.
Where am I going wrong?
The code is as follows
| Code: | //////////////////////////////////////////////////////////////////////////
/// @file BarcodeScanner.C
/// Author: Simon Nixon
/// IDE: MPLAB
/// Compiler: CCS
/// Test Harness: Barcode_scanner
/// Description:
/// This is the main file that will read a string from a barcode
/// scanner and display it on a 2x16 LCD screen.
#include <18F458.h>
#use delay(clock=8000000)
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#include <lcd.c>
#include <stdio.h>
// declare global variables
char Barcode[17];
char Buffer[17];
// initialise hardware
lcd_init();
// create local variables
// initialise local variables
// mainloop
while(true)
sprintf(Buffer, "Ready...");
printf(lcd_putc, Buffer);
gets(Barcode);
printf(lcd_putc, Barcode);
Please can anybody help me with this project? |
Posted: Sun Jan 07, 2007 9:55 am |
Have you got a MAX232 or equivalent inverter/level translator present. Remember the PIC is 5v serial, inverted from what is coming out of the PC.
Second comment, what is the output format of the scanner?. Are you sure that the 'lines' are never more than 16 characters in length, and is terminated with a CR?. Hyperterminal, won't mind if the strings are longer.
Personally, I'd include 'input.c', in the code, and use 'get_string', rather than 'gets', with a maximum of 16. This is always safer.
Simnix
Posted: Mon Jan 08, 2007 10:20 am |
I am using the millennium board at the moment, C6 & C7 (xmit & rcv) are connected to TX1 & RX1 respectfully, so the voltage levels are handled by the on-board max232.
The scanner is a Touch65 Pro with a RS232 connector and the scanner terminates with CR. I think barcode are in general 11 characters long.
No I haven't used input.c, I will give it a try, you see I am new to PIC programming and have never dealt with serial before, so this is going to be a steep hill for me to clime.
Regards |
