Greg_R
| EEPROM losing data |
Posted: Tue Dec 19, 2006 4:54 pm |
I have one of three systems that loses the data stored in it's eeprom when the power is cycled. Ttelmah talked about an over voltage condition on MCLR can cause this. I'm looking for more information...
Thanks,
Greg |
Posted: Tue Dec 19, 2006 5:08 pm |
Try to isolate the failure mechanism.
First thing, find out if it's occurring due to your writing of the eeprom.
Coment out the lines of code that write to the eeprom. Then run your
program and see if you still get the failure. (Initialize the eeprom to
some suitable value when you program the PIC with the ICD2). |
Greg_R
| More details |
Posted: Tue Dec 19, 2006 6:42 pm |
PIC18F8722 with 40MHz TTL Oscillator.
Linear Power Supply that has a clean, monotonic ramp. ~5.5ms to 5V.
MCLR is tied to VCC through a 47k resistor per CCS.
Compiler: 3.249
I was told the PIC was replaced but am not 100% certain of that.
I saw no problem with either MCLR or VCC while cycling power a number of times.
Steps:
Verified, using an ICD-U40, that the EEPROM was blank.
Ran the code to store the struct in EEPROM and stopped execution.
Verified that the values had been written.
Started excecution.
Cycled the power.
Checked the EEPROM and it was once again blank.
Greg |
Posted: Tue Dec 19, 2006 7:13 pm |
I have these questions:
1. Was this recent test done while the PIC is being controlled by the
CCS ICD-U40 debugger ? Or was it run in stand-alone mode ?
2. When you did the test, was it done with the changes made that
I suggested in my post ?
In my post, I suggested that you should comment out all lines of
code that write to the internal eeprom. Example:
| Code: | | // write_eeprom(addr, data); |
I also suggested that you preset the internal EEPROM values, so that
they are programmed when the PIC is programmed, and at no other
time. Example:
| Code: | | #rom int 0xF00000={1,2,3,4} |
Also, your tests should be done completely in stand-alone mode.
The debugger should not be attached to the board. |
Greg_R
| The saga continues |
Posted: Wed Dec 20, 2006 7:38 pm |
I attempted to use the #rom as suggested and it fails to program on the three systems I tried it on. The following compiles fine but fails the verification step of programming with an ICD-U40.
#include <18F8722.h>
#device *=16
#device adc=8
#FUSES NOWDT, WDT128, EC_IO, NOPROTECT, IESO, BROWNOUT, BORV25, PUT, NOCPD
#FUSES STVREN, NODEBUG, NOLVP, NOWRT, NOCPB, NOEBTRB, NOEBTR, NOWRTD, NOWRTC
#FUSES NOWRTB, FCMEN, LPT1OSC, MCLR, NOXINST, MCU
#use delay(clock=40000000)
#use rs232( stream = PC, baud=115200, parity=N, xmit=PIN_G1, rcv=PIN_G2, errors )
#define RLED PIN_F7
#define YLED PIN_H5
#rom int8 0xF0000 = { 1, 2, 3, 4 }
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_4(T4_DISABLED,0,1);
setup_vref(VREF_LOW|-2);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
output_low( RLED ) ;
output_high( YLED ) ;
delay_ms( 350 ) ;
output_high( RLED ) ;
output_low( YLED ) ;
delay_ms( 350 ) ;
while( 1 )
if( read_eeprom( 0x0000 ) == 1 )
delay_ms( 100 ) ;
delay_ms( 100 ) ;
Any ideas what my stupid mistake is??? |
Posted: Wed Dec 20, 2006 7:54 pm |
Count the number of zeros in your eeprom address, compared to my
sample code. |
Greg_R
| Hitting the PostReply seems to high light stupid mistakes... |
Posted: Wed Dec 20, 2006 8:01 pm |
The #rom should be:
#rom int8 0xF00000 = { 1, 2, 3, 4 }
not:
Couldn't see it for two hours but post it...
It works. Back to the hole. |
