hadeelqasaimeh
ps2 |
Posted: Sun Dec 17, 2006 6:29 am |
hi all;
according to the following link:
http://www.ccsinfo.com/forum/viewtopic.php?t=25673&highlight=ps2
i try to use this new library,,when i add an lcd library "lcd_kbd1.c" its make an error!! while "lcd.c" don't!! why?
here is my lcd_kbd1 library:
#include <jonsinc.h>
// These defines are specifically for a 4x16 line display.
#define LINE_16_1 0x00
#define LINE_16_2 0x40
#define LINE_16_3 0x10
#define LINE_16_4 0x50
// These defines are specifically for a 4x20 line display.
#define LINE_20_1 0x00
#define LINE_20_2 0x40
#define LINE_20_3 0x14
#define LINE_20_4 0x54
// Another define for use in LCD_PutCmd
#define CLEAR_DISP 0x01
// This is a macro used in the subroutines below */
#define PULSE_EN EN = 1; delay_us ( 10 ); EN = 0; delay_ms ( 5 )
#byte port_e = 9 /* set variable that maps to memory */
#byte PORT_A = 5 /* set variable that maps to memory */
#byte port_b= 6
#byte PORT_D= 8
#byte DATA = PORT_A
#bit RS = port_e.0
#bit EN = port_e.1
char kbd_getc(void);
char getkey ( void );
// These are prototype statements.
void LCD_SetPosition ( char cX );
void LCD_PutChar ( char cX );
void LCD_PutCmd ( char cX );
void LCD_Init ( void );
// These are the display subroutines.==============================
// Initializing into 4-bit mode is a very exact sequence
// as defined in the datasheets for these displays.
set_tris_a ( 0x00 ); /* outputs */
set_tris_b ( 0xFC ); /* Bits 0 & 1 are outputs */
set_tris_e ( 0xF0 );
DATA = 0x00;
delay_ms ( 200 ); /* wait enough time after Vdd rise */
RS =0;
DATA = 0x03; /* init with specific nibbles to start 4-bit mode */
PULSE_EN;
PULSE_EN;
PULSE_EN;
DATA = 0x02; /* set 4-bit interface */
PULSE_EN; /* send dual nibbles hereafter, MSN first */
LCD_PutCmd ( 0x2C ); /* function set (2 lines, 5x7 characters) */
LCD_PutCmd ( 0x0E ); /* display ON, cursor on, no blink */
LCD_PutCmd ( 0x01 ); /* clear display */
LCD_PutCmd ( 0x06 ); /* entry mode set, increment */
void LCD_SetPosition ( cX )
This subroutine works specifically for 4-bit Port A.
Value received cX will place cursor at a particular line and offset.
16-char display 20-char display
Line 1 is hex: 00 - 0F 00 - 13
Line 2 is hex: 40 - 4F 40 - 53
Line 3 is hex: 10 - 1F 14 - 27
Line 4 is hex: 50 - 5F 54 - 67
DATA = swap ( cX ) | 0x08;
PULSE_EN;
DATA = swap ( cX );
PULSE_EN;
void LCD_PutChar ( cX )
/* this subroutine works specifically for 4-bit Port A */
RS = 1;
DATA = swap ( cX ); /* send high nibble */
PULSE_EN;
DATA = swap ( cX ); /* send low nibble */
PULSE_EN;
RS = 0;
void LCD_PutCmd ( cX )
PULSE_EN;
PULSE_EN;
/* Include this file by inserting the line "#include <jonsinc.h>" at
the beginning of the C source code. Or, if you prefer, you can embed it's
contents at the end of each of your 12C509H, 16F84H, 16F874.H, etc. files.*/
#case
#ifndef TRUE
#define TRUE 1
#ifndef FALSE
#define FALSE 0
#ifndef YES
#define YES 1
#ifndef NO
#define NO 0
#ifndef HIGH
#define HIGH 1
#ifndef LOW
#define LOW 0
#ifndef ON
#define ON 1
#ifndef OFF
#define OFF 0
#ifndef UP
#define UP 1
#ifndef DOWN
#define DOWN 0
#ifndef UCHAR
#define UCHAR char
#ifndef UINT
#define UINT long
#ifndef BIT
#define BIT short
#ifndef SCHAR
#define SCHAR signed int
#ifndef SINT
#define SINT signed long
#ifndef FLOAT
#define FLOAT float
so... |
hadeelqasaimeh
Posted: Sun Dec 17, 2006 7:40 am |
What is the error message you get?
Which compiler version are you using?
Code: | #use delay(clock=20000000) | Don't put this line here, have it in the same file where the #fuses line is. Now you are runing the risk of declaring the clock speed twice with unknown results. |
hadeelqasaimeh
Posted: Mon Dec 18, 2006 10:01 am |
it give this message
undefined identifier PS2KEY_BUF_SIZE
my compiler is 3.249 |
hadeelqasaimeh
Posted: Thu Dec 21, 2006 1:22 am |
helllllooo!!!
nobody can help? |
Posted: Thu Dec 21, 2006 1:37 am |
Quote: |
it give this message,
Notice that in your code, you have this statement:
Notice that in John Leung's code, he spells that constant name
two different ways. He doesn't use the #case statement in his
code, so he doesn't get an error.
PS2Key_BUF_SIZE
PS2KEY_BUF_SIZE
