| Help interrupt : NEWBIE |
Posted: Wed Dec 06, 2006 12:56 pm |
Hi guys , i know it is probably simple , but i can't find why this simple code doesn't work
all i want a do with it , is to change the value set in timer1 using an analog input, varying the analog should change the speed of the blinking LED , i have been able to do it in 8 bits using Timer0 but not in 16 bit with timer1
Thanks for your help!!
Bruno
here the code
#include <16F676.h>
#device adc=10
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
#use delay(clock=4000000) // 4MHz clock
long atime=0;
long itime=0;
byte i;
#INT_TIMER1
void Timer1()
set_timer1(atime);
if (itime==512)
output_low(PIN_A5);
output_high(PIN_A4);
output_low(PIN_A5);
output_low(PIN_A4);
if (i==1)
output_high(PIN_A1);
output_low(PIN_A2);
i=0;
output_low(PIN_A1);
output_high(PIN_A2);
i=1;
set_tris_a(0xf1); //
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
set_timer1(atime);
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_DIV_16);
while(1==1)
set_adc_channel(0);
itime=read_adc();
delay_us(50);
atime=itime;
mindstorm88
Joined: 06 Dec 2006 Posts: 102 Location: Montreal , Canada
| Re: Help interrupt : NEWBIE SOLVED |
Posted: Wed Dec 06, 2006 12:58 pm |
Oups i'm the author
| Anonymous wrote: | Hi guys , i know it is probably simple , but i can't find why this simple code doesn't work
Bruno
here the code
#include <16F676.h>
#device adc=10
long atime=0;
long itime=0;
byte i;
#INT_TIMER1
void Timer1()
set_timer1(atime);
if (itime==512)
output_low(PIN_A5);
output_low(PIN_A5);
output_low(PIN_A4);
if (i==1)
output_low(PIN_A2);
i=0;
output_low(PIN_A1);
i=1;
set_timer1(atime);
while(1==1)
set_adc_channel(0);
itime=read_adc();
delay_us(50);
atime=itime;
mindstorm88
Posted: Thu Dec 07, 2006 8:22 am |
Sorry guys , don't waste your time on it !!!, everything is working OK , my loop is so long that i could not see the speed change of the leds !!!!  |
