RA Guest
PIC16f877A PWM not fully on |
Posted: Mon Nov 13, 2006 9:20 pm |
You won't be able to see this well unless you have at least a 100Mhz
O-scope and 100 Mhz probes. I'm using a tek 2246.
I notice when the PR2 reg is set to 255 and 1023 in entered into the
ccpr1L/cc1con register the pwm output will go low(0v) for 50ns(20Mhz) every 51us(19.57)Khz and stay high(5v) for the rest of the duration.
Yes, I do have 2x 10nf and 2x 100nf cap right on the Vdd and Vss pins.
The supply voltage is very clean.
Here's a simple test prog.
PCWH v3.249
Pic16f877A is REV B6
It's no big deal.
Microchip's PIC's never do exactly what they're advertised to do.
I've been bitten by their erratas in the past.
#include <16f877A.h>
#include <stdlib.h>
#fuses HS,PUT,BROWNOUT
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#use fast_io(d)
#use fast_io(e)
void MAIN() {
output_a(0);
output_b(0);
output_c(0);
output_d(0);
output_e(0);
SET_TRIS_A(0);
SET_TRIS_B(0);
SET_TRIS_C(0);
SET_TRIS_D(0);
SET_TRIS_E(0);
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
setup_timer_2(T2_DIV_BY_1, 255, 1); // 10 Bit 19.53Khz
set_pwm1_duty(1023);
set_pwm2_duty(1023);
while(true){}
asm list:
.................... setup_ccp1(CCP_PWM);
0023: BCF 03.5
0024: BCF 07.2
0025: MOVLW 0C
0026: MOVWF 17
.................... setup_ccp2(CCP_PWM);
0027: BCF 07.1
0028: MOVWF 1D
.................... setup_timer_2(T2_DIV_BY_1, 255, 1); // 10 Bit 19.53Khz
0029: MOVLW 00
002A: MOVWF 78
002B: IORLW 04
002C: MOVWF 12
002D: MOVLW FF
002E: BSF 03.5
002F: MOVWF 12
.................... set_pwm1_duty(1023);
0030: BCF 03.5
0031: MOVWF 15
0032: MOVF 17,W
0033: ANDLW CF
0034: IORLW 30
0035: MOVWF 17
.................... set_pwm2_duty(1023);
0036: MOVLW FF
0037: MOVWF 1B
0038: MOVF 1D,W
0039: ANDLW CF
003A: IORLW 30
003B: MOVWF 1D
Posted: Tue Nov 14, 2006 8:27 am |
This is fairly normal.
If you were designing such a circuit, there is a problem with handling the 'ends' of the range. You have to make a decision, whether the reset, occurs before, or after the set in the clock cycle. The Microchip solution, is to have this configured, so a 0, does give nothing out, but this implies that at the other end of the range, a full-on, will result in one clock of low output. They have a hardware 'trap', so that if the output _exceeds_ the full-on value, the line gets permanantly turned on, but a value that _matches_ the full on count, on some chips gives a single low output cycle as you are seeing.
The same is true on quite a few other PWM chips (not just PICs). You can program round it, if a lesser PWM maximum count is acceptable, by setting timer2, to 254, and then if the required value on the pulse width is >=1020, setting the value to 1023, which then triggers the extra hardware.
RA Guest
Posted: Tue Nov 14, 2006 1:46 pm |
Yep, I thought so.
I suppose that's close enough by microchip standards.
On 18f parts it's much better
Darn those silicon propagation delays.  |
